2 instances of RRConfig = RR broken!
I accidentally opened 2 instances of RRConfig and launched RR from one of them and RR broke. Now, when I launch RR I get the default, blue/lightning loader followed by:
"C:\...Skins\ does not contain a valid skin! Check your settings and try again. Details in Debug.txt"
The skin appears intact in my Skins folder (also tried reinstalling the skin) and RRConfig is still set up to use this skin and the config preview of the skin still works. I had this happen one other time and that time it deleted everything from my Skins folder and I had to reinstall RR. I'd prefer not to do this again/not to have this issue again! The only debug.txts I found (attached) on my system is are in plugin folders for RRFuelPrices (two locations - on in C:/Documents and Settings\...\Plugins\RRFuelPrices and one in C:\Program Files\...\Plugins\RRFuelPrices) and one in the RRUpd8 folder (C:\Docments and Settings\...\Plugins\RRUpd8). I tried removing these plugins but it didn't help. RR always gets to "Starting Skin Tool..." and fails with the above warning. Any ideas?
Update: I relinked RRConfig to the skin folder and now RR launches with the proper loader for my skin but instead of RR opening I get a gray box that takes up roughly 1/6 of my screen and does nothing.
