doing some flash skinning i found a little issue, not sure if is a bug or is me not using the command correctly, heres whats happening.
i need to poll a variable data, using this.
so if i ask for a label i.e.Code:Label Polling from Flash: fscommand("GETLABEL","<LABEL CODE>");
You may receive empty labels if they don't exist or are not used by RR at the current time.
You may also poll RR VARIABLES using the syntax: fscommand("GETLABEL","=$MYVAR$")
i get _root.TIME this works perfectlyCode:fscommand("GETLABEL", "Time")
BUT if i ask for a variable like this
_root.RRDROID_PATH is not created, i tried _root.$RRDROID_PATH$ nothing as well. so im asking for any help or guide on how to achieve what im after. thanks in advance.Code:fscommand("GETLABEL", "=$RRDroid_PATH$")
as of now, im using upon loading the screen,NOTE: i tried with known variables like "RRPATH" and "SKINPATH" just to make sure my custom var isnt the issue, and is the same.Code:SetFlashVar;RRDroid_PATH;$RRDroid_PATH$
