Results 1 to 9 of 9
Thread: RideRunner Skin issue
    Aug 2006
    I have the DFX plugin and it's a fresh install of both.
    No matter how much I clean out and make sure it's a fresh install (when doing stuff like updating RR because of a new version and getting nagged that it's out of date) I still get this problem.
    Here's the error message (and I will include a screen shot of it):
    "RideRunner screen loading error!
    While loading: menu1.skin
    menu1.skin not found."
    This happens when I tap on "Menu" to go between the 4 different menus within DFX.
    Any ideas?
    Here's a link to the screenshot:
    2006 Mazda 3 S Series
    2.3L 4cyl Engine
    Current Build
    - Commell LV-677 Motherboard
    - Intel Core 2 Duo T5500 CPU
    - Dual 512MB PC5300\667MHz RAM
    - Seagate 80GB SATA HDD
    - M2-ATX 160W PSU
    - Dynamix 8" LCD Touchscreen
    - VoomPC I Mini-ITX Case (Black)
    MySQL Error
    Oct 2004
    did you check for actual existince of that file?
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Aug 2006
    Yeah, until I realized I didn't know where it was supposed to go when I didn't find it lol
    Why isn't the installer properly copying this file? I'm doing complete clean install, removing all traces even in hidden folders such as the /Application Data/ folder
    2.3L 4cyl Engine
    Current Build
    - M2-ATX 160W PSU
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Looks like there is a space between the the 1 after menu and the fullstop.
    either edit the filename of menu1.skin to menu1 .skin
    or where in the skin it's trying to call that feature
    Aug 2006
    Quote Originally Posted by Enforcer View Post
    Why am I having to do this though? lol
    It's literally a fresh install.
    Which file(s) reference the skin file?
    2.3L 4cyl Engine
    Current Build
    - M2-ATX 160W PSU
    Variable Bitrate eugenweij's Avatar
    Aug 2010
    Rozenburg, Netherlands
    depends if your plugin is installed in the same place as your RR
    your RR can be installed in normal or profile mode, this goes for the plugins as well, most plugins have one mode set on auto , riderunner installs in profile mode by default
    in normal mode all skin and plugin files are located in the RR folder on your c:\program files\riderunner, in profile mode all your skin and plugin files are installed in your documents\riderunner
    check if both plugin and riderunner are installed in the same mode
    View my worklog here
    MySQL Error
    Oct 2004
    also what exactly is a dfx plugin? to me its a skin...
    and it is responsible for that file
    prob best to post this in the DFX skin thread...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    and btw, my dfx skin goes
    menu.skin
    menu2.skin
    menu3.skin
    menu4.skin
    the command to get to the next skin is "DFX_MainMenuNext"
    not sure where that is handled...
    could be in the exectbl, could be it the dfx support plugin (looks like in the dfx support plugin)
    which should be installed by the dfx installer...
    best to post all this in the dfx thread, where actuall users of the skin can help you
    you know my thoughts, test with carwings....
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Aug 2006
    I did the standard install, also, I did this after removing ALL traces of RR from my system (including My Docs) so why am I having this issue?
    Why am I having to troubleshoot where there's a skin file missing or to check if it's properly named?
    I never chose which mode I wanted to install, there isn't even an option for that in the installer I used (2/1/2013) for DFX 5.1 and the latest RR.
    Are you saying the issue is apart of DFX and not RR?
    Sorry for the super late reply, been real busy lately with school and work and moving out to go to a different college, etc.
    But yeah, I'll check out the DFX thread instead. Thanks guys.
    2.3L 4cyl Engine
    Current Build
    - M2-ATX 160W PSU
  1. I am...MOSO ( skin for riderunner )
    By anuchit in forum RR Skins
    Last Post: 10-29-2011, 05:31 AM
  2. Problems 2 skin RideRunner
    By Carlo201983 in forum Road Runner
    Last Post: 03-09-2011, 01:27 AM
  3. another riderunner sound issue
    By Joshc8503 in forum Road Runner
    Last Post: 03-19-2010, 08:54 PM
  4. Help with riderunner and elite lite skin
    Last Post: 02-12-2010, 11:16 AM
  5. Riderunner issue with XM
    By chgrec in forum Road Runner
    Last Post: 04-22-2009, 07:26 PM
