Results 21 to 30 of 31
Thread: Weather not displaying symbol
  1. #21
    MySQL Error
    Oct 2004
    you wont see any garbage, if the setting is un altered in RR.ini
    AND its NOT in skin.ini or general.ini of the loadeded
    the file is being written wrong, you can also be doing it
    ONLY USE a GOOD TEXT EDITOR
    REMEMBER UNICODE!
    you dont neeed to go any father than, looking at your files... when the symbol is bad
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #22
    MySQL Error
    Oct 2004
    also, RRCONFIG, may be getting the file encoding wrong...
    make sure your using the newest RR with the newest RRConfig...
    all you have to do is look at ur files! and you will know
    since i use rrconfig all the time, i dont suspect it
    but it might be writing it WRONG in skin.ini!!!
    thats why you have to lOOOK!!!!
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  3. #23
    Oct 2012
    Quote Originally Posted by mitchjs View Post
    Are you saying the character is stored in each of those files? I don't understand your comment.
    REMEMBER UNICODE!
    To be clear, I did not edit any files when I repro'd this error. It has to be something in RRConfig causing the problem - from what I can see. To re-cap:
    1. If I run the DFX 5.1.2 installer, and then check weather, the degree symbol appears correctly.
    2. If I then quite RR, open RRConfig and modify at least some things (I have not had time to determine if it's a question of modding any settings or just some particular settings in RR Config), when RR Config is closed and RR is re-started, the weather degree symbol is corrupted (i.e. get garbage display)
    3. If I don't ever run RR Config after running the DFX 5.1.2 installer, then it's fine and all is well (i.e. degree symbol appears as desired)
  4. #24
    Oct 2012
    That is what I suspect. I am using the RR Config that came with the January 2013 RR installer. I also saw this problem with the December 2012 install package.
    Not if I don't know which file or what I'm looking for.
    I don't mind helping debug, but you need to provide some guidance on what to look for and where to look.
    LIke I said above - please indicate where to look and what to look for. I'm glad to help out, but off the top-of-my-head I don't know where the degree symbol is pulled from.
    I recall that when I've looked at some of the files previously (before I posted on the forum about this), they all seemed to have the correct symbol. I tried to troubleshoot this before posting, thinking the same thing that there was some file getting corrupted. But now I know at least one pattern of behavior that will re-produce the problem, and I can't find the garbage text anywhere in any file (so far).
    If you think the characters are being written incorrectly to an ini file, give me a list of files to check (If you can determine that). Where could RR pull the text from in order to print it on the weather screens?
  5. #25
    MySQL Error
    Oct 2004
    i mentioned this a few times
    its pulled from rr.ini
    but may be overrided from skin.ini and or general.ini
    use carwings only right now
    in the carwings folder there is skin.ini and general.ini
    check them remove any weather references!
    then only rr.ini is in play
    in rr.ini:
    [Weather]
    WeatherDayNameLength=3
    WeatherUnits=USA
    WeatherDegrees=
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #26
    MySQL Error
    Oct 2004
    also keep debugging on, so you can review the debug.txt file
    that tells you alot!
    [Debuging]
    DebugMode=True
    DebugFresh=True
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #27
    Variable Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    @RadarNutt
    Quick fix as much as I tested so far only a handfull of times but so far it is working.
    In the DFX skin.ini the line weatherdegrees= I changed to [weatherdegrees=] use the brackets (or remove the whole line if you want)
    I tried leaving it blank like weatherdegrees= but that did not work for me.
    Then I had to manually edit the rr.ini with notepad, the line WeatherDegrees= (it looked like it was correct but I put it in there again) and did the alt 0176 to get the symbol
    If I used RRCONFIG to change the symbol it would not work. I changed it, saved it, closed RRCONFIG reopened RRCONFIG and it was something different. I tried that a few times. Also I did not open RR during this process.
    See if this helps
    Win 7 Pro 64bit, 4gb DDR2 Ram, q6600 Processor, Solid state drive & 7200 drive, Andrea mic, Sirius, DE HD Radio, Opus power supply, 10.4" touchscreen.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    2.) Sets Orion Components - P-SERIES
  8. #28
    MySQL Error
    Oct 2004
    [Debuging]
    DebugMode=True
    DebugFresh=True
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #29
    MySQL Error
    Oct 2004
    here is the FIXED DFX skin file Weather_Icon_Choices.skin
    i only changed one line:
    Code:
    B,201,258,106,42,"SETVAR;weatherdegrees;||SaveToini;weatherdegrees;",
    make sure you remove "weatherdegrees=" from
    (JUST DELETE THE LINE)
    skin.ini and skin(orig).ini and any of your BACKUP skin.ini's
    these are in the skins/dfx5 folder
    and then you can use DFX5 or RRCONFIG to SET you symbol
    he was using 0186 NOT 0176 (proper)
    Attached Files Attached Files
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #30
    Oct 2012
    Mitch,
    Thanks very much.
    BTW, have you informed John of this issue in DX5?
  1. Replies: 6
    Last Post: 08-13-2010, 12:57 PM
  2. Replies: 14
    Last Post: 08-18-2009, 02:04 AM
  3. Help me with this symbol...
    By popi79 in forum General Hardware Discussion
    Last Post: 02-19-2007, 02:09 PM
  4. need to send key to S&T, what symbol?
    By vfinterceptor in forum GPS
    Last Post: 04-18-2006, 05:58 PM
  5. Bulgin Pushbutton with Power Symbol?
    By SpaceMonkey in forum General Hardware Discussion
    Last Post: 01-29-2006, 08:37 AM
