Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: Weather not displaying symbol
    Variable Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    The weather is not displaying symbol.
    What am I missing?
    Yes I checked with carwings
    Win 7 Pro 64bit, 4gb DDR2 Ram, q6600 Processor, Solid state drive & 7200 drive, Andrea mic, Sirius, DE HD Radio, Opus power supply, 10.4" touchscreen.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    2.) Sets Orion Components - P-SERIES
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    The font you're using might not support the degree symbol. Change the font in DFX and see if it fixes it.
    Live mp3Car Facebook Chat
    MySQL Error
    Oct 2004
    there is a setting
    spoon feeding...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Feb 2005
    Huntsville, AL
    Quote Originally Posted by mitchjs View Post
    there is a setting
    spoon feeding...
    Tried that before it dont work I put the symbol in there but then it displays as in the pic.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    Raw Wave
    Nov 2009
    Could it be a corrupt font file or that Western ISO-8859-1 is not being used?
    Otherwise if the extended ascii characters can be mapped:
    = 176(dec) 260(oct) B0(hex) 10110000(bin) (html).
    See also howeird's http://www.howeird.com/charmap.html (not that the GUI is html, but it's a ref I've used for ages).
    Sorry if this is way off. It's not my usual battery & electrical subject.
    It reminds me of why I use "R" instead of "Ω" - apart from its ease, it's confusing seeing 100Ω displayed as 100W.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    It could the way the text is displayed in the webpage.
    the text will be web compliant which means they stick &amp in there to allow extended characters to display correctly.
    May need to convert that in code when scraping the info.
    MySQL Error
    Oct 2004
    Quote Originally Posted by michaelrj9 View Post
    works for me...
    you know the rule...and if you dont, here it is.... Test in carwings...
    (also did you actually look at rr.ini?)
    Code:
    [Weather]
    WeatherDayNameLength=3
    WeatherUnits=USA
    WeatherDegrees=
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Oct 2012
    What am I missing?
    I am having the same problem. Just started a few days ago. Nothing else changed - no change to fonts, etc. on the PC, no updates to RR or DFX skin, etc. Nada. I believe Enforcer must be right - there must have been a change to the data stream.
    Can someone who understands the raw data coming down take a look and do a compare with older data? There must be something that changed.
    I've tried all the tricks to fix the display to the degree symbol (), including editing the RR.ini, etc. (which should not be necessary to begin with given no other changes). It makes no difference. It is NOT a font problem! (at least that is not the core issue)
    Oct 2012
    works for me...
    OP did. See his posts above.
    MySQL Error
    Oct 2004
    i just ran weather now... i see the the degree symbol... just fine
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Replies: 6
    Last Post: 08-13-2010, 12:57 PM
  2. Replies: 14
    Last Post: 08-18-2009, 02:04 AM
  3. Help me with this symbol...
    By popi79 in forum General Hardware Discussion
    Last Post: 02-19-2007, 02:09 PM
  4. need to send key to S&T, what symbol?
    By vfinterceptor in forum GPS
    Last Post: 04-18-2006, 05:58 PM
  5. Bulgin Pushbutton with Power Symbol?
    By SpaceMonkey in forum General Hardware Discussion
    Last Post: 01-29-2006, 08:37 AM
