Results 1 to 8 of 8
Thread: RR plugin written in C++
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Is it possible to write a RR plugin with the language C++ ?
    with the IDE Code::Blocks or Visual C++
    MySQL Error
    Oct 2004
    course it is...
    rr doesnt care what you code in...
    (ill be it, C++ much harder lang to code in, if you dont do it day to day)
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    May 2008
    Bordeaux, France
    Quote Originally Posted by mitchjs View Post
    course it is...
    If you have a little example RR plugin written in C++ that would be cool !
    MySQL Error
    Oct 2004
    i dont... sorry...
    you would have to learn about com object programming...
    its much much much much harder to do in C++....
    dont see the point...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    May 2012
    Grandville, MI
    RR is written in Visual Basic if I am not mistaken?
    Would be nice if it were rewritten in Visual Basic .net but that would require a full rewrite...
    Since it is written for a PC and won't run on anything else you might consider C# which is sort of a mixture of C++ and .net. No point in writing in C++ unless you are going to port it over to other computers since C# is MUCH more compact and much faster to write than C++.
    I believe RR should let you include just about any binary as a plugin so you should be fine?
    May 2008
    Bordeaux, France
    Quote Originally Posted by redheadedrod View Post
    I know that !
    I write (very bad) already in VB.NET and C# but i should like learn the C++
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    i agree with mitch, C++ is not for the faint of heart, not trying to say you wont be able to handle it, but is the hardest coding language to work with. unless you have plenty of time to learn it if not, avoid it. i have been reading about C++ for quite some time, and yet i go C# or vb.bet at the end. all i have done was add some stuff to activewinamp source and that was done most of it already. have a look to that it uses com object, so you can have a starting point there.
    May 2012
    Grandville, MI
    Quote Originally Posted by EL CAMINO View Post
    C++ actually is not any harder than any of the other languages. Realistically C# is MUCH more complicated to learn from my current experience. HOWEVER with C++ you will have to do most of the writing yourself where as the other languages simplify steps with routines or built in libraries that do it for you. C++ is the most universal language out there. You can write code for Windows PC's, Linux/WebOS/Android and many of the embedded OS's use C++ as their code base. I am unfamiliar with Mac/iOS but I am assuming they can also use C++ to write for them as well. It really boils down to the differences in the libraries supported by each different type of computer. Also, C/C++ is the model most of the common languages use to start out with. But as an example, you can use C# and some .net code and write a routine in like 3 lines that may take you 30 in C++.
    Rodney
  1. RR plugin written in C#
    By pierrotm777 in forum RR Plugins
    Last Post: 10-02-2012, 07:50 AM
  2. What language is RoadRunner written in...
    By stupidjunior in forum Road Runner
    Last Post: 04-17-2007, 03:30 AM
  3. In what language is StreetDeck Written?
    By skyhawk2114 in forum StreetDeck
    Last Post: 08-12-2006, 11:57 AM
  4. GPS software i've written...
    By RiPz in forum GPS
    Last Post: 02-27-2006, 03:56 PM
  5. Replies: 4
    Last Post: 02-02-2006, 03:20 PM
