I'm having trouble with Volume control and Winamp. The problem is the volume +/- buttons do not work. Pressing them yields the 'click' wav sound, but no action seems to be performed.
This is true with RR version 12/2012 and 01/2013, using CarWings Lite and using DFX 5.1.2 skins. I've checked the debug logs and they show the button press, but that's it.
Winamp version is 5.63. All drivers, Flash, plugins, etc. are up to date. I also tried this on a fresh install of Windows XP SP2 and the 01/2013 RR code, before installing anything else - same problem.
The volume % indicator also does not change. It is stuck at 50%. The volume level (sound) does not change either. If I go into the Windows sound controls, via the Taskbar/quick launch bar, they work fine. So, I know it's not a hardware or Windows issue (and I'm running Win XP SP2 btw).
I don't know if this is an issue with RR core code, Carwings Lite, or Winamp. I would think it's most likely a communication issue between RR and Winamp, except I'd expect the volume % to change even if the volume didn't physically change, and those % indicators are not changing.
I've searched the files on the PC for "Vol+" and "Vol-" and tried playing with lines in various INI files, but nothing makes a difference. I'd like to try and modify the commands sent to Winamp to see if that would work (since Winamp supports various keyboard combinations), but I cannot find anything that I can modify (e.g. INI files) that seems to affect the communication with Winamp, so right now I'm stuck.
I've searched this forum quite a bit, but all the threads on Winamp and volume issues are 1) quite old; and 2) different problems than what I'm describing.
I'm stumped. :(
