Results 1 to 3 of 3
Thread: Getting explerer.exe to run in background????
    Maximum Bitrate locs4dayz's Avatar
    Sep 2009
    Philadelphia, PA
    I have edited my windows registry so that RR is now my default GUI upon booting up windows XP(Here are the detailed instructions on how to do this...http://www.mp3car.com/winnt-based/14...ng-xp-gui.html). Now I have to start explorer.exe from the task manager whenever I need to minimize to use the default windows GUI or access the start menu. My question is...Is there a way to have explorer.exe load by default in the background so I don't need to use the task manager to run it? If not then I will have to revert back explorer.exe being the default GUI and RR being a startup item like I originally had it, but I prefer my new setup better.....thanks in advance
    If I can get this done....my next move is to disable my login screen too, since I'm going for the OEM look and feel. I have already edited my boot screen to display my ford logo instead of the standard windows logo using tuneup utilities!!!
    Linux(Learning the curve...Like when driving!!!)
    Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
    Sep 2012
    Germany - Munich
    for automatic logon:
    -disable the new logon screen in useraccount settings
    -then windows-key+R
    -type control userpasswords2 -> Enter
    -uncheck the box and OK
    -type username and password(if needed)
    to set a bmp as background for logonscreen set registry:
    Code:
    Windows Registry Editor Version 5.00
    [HKEY_USERS\.DEFAULT\Control Panel\Desktop]
    "Wallpaper"="C:\\Programme\\RideRunner\\Skins\\OpenBM_E39\\AUDIO\\loader.bmp"
    to disable the small window during the logon. add this to registry:
    Code:
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\system]
    "DisableStatusMessages"=dword:00000001
    change logon-background color to black (R G B):
    Code:
    [HKEY_CURRENT_USER\Control Panel\Colors]
    "Background"="0 0 0"
    to switch between bootsequences in RideRunner, i use these cmd-batchfiles by button and QUIT("RUNQ;$SKINPATH$Scripte\XXXXX.cmd||QUIT"):
    -for normal windows boot
    Code:
    reg add "hklm\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon" /v Shell /t reg_sz /d explorer.exe /f
    xcopy "C:\bootXP.ini" "c:\boot.ini" /Y /R /H
    ping -n 5 localhost> nul
    shutdown /r /t 00
    -for RideRunner boot
    Code:
    reg add "hklm\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon" /v Shell /t reg_sz /d C:\Programme\RideRunner\RideRunner.exe /f
    xcopy "C:\bootRR.ini" "c:\boot.ini" /Y /R /H
    shutdown /r /t 00
    ping for simple delay, that RR has enough time to Exit.
    i use xcopy, because i have two different boot.ini files.
    watch my video for my bootsequence:
    http://www.youtube.com/watch?v=9cQ4ok4Ot64
    BE CAREFUL BY EDITING REGISTRY OR BOOT.INI
  1. Background
    By venealis in forum RR Skins
    Last Post: 08-13-2007, 12:03 PM
  2. My first SD background
    By geeky_hawkes in forum StreetDeck Skins
    Last Post: 02-24-2007, 10:45 AM
  3. Help - no background shown
    By PThomas in forum PhoneControl
    Last Post: 12-22-2004, 10:01 AM
  4. New background image!
    By Confused in forum General MP3Car Discussion
    Last Post: 09-02-2004, 08:30 AM
  5. XM PCR - background noise
    By blazinlow in forum General Hardware Discussion
    Last Post: 08-29-2004, 01:19 PM
