Any advice please?
Good afternoon,
I've been using DashCommand embedded in RideRunner for many years now but just upgraded to v3.0.1 (Build 2770). It loads very much faster (thanks PPE). The only two issues I have is that:
- the focus stays on DashCommand and doesn't return to the FrontEnd app (RideRunner) - Pic and code below
- and, I don't seem to be able to get -autostart or -startindashboards to work (I have tried adding ¦ -autostart -startindashboards after dashcommand.exe)
LOAD;obd.skin;DashCommand;C:\Program Files (x86)\DashCommand\dashcommand.exe;DashCommand
I would welcome any advice as I'm always using this app, I just have to return to main menu and back to obd at the moment, which is not very slick
Cheers,
Dave
Vauxhall Astra SXi Car PC installed.
Any advice please?
Just the usual
1.
Check the name for embedding is correct.
Does the new version allow itself to be resized.
2.
Have you tested those switches outside of rr?
I've used FindWindowInfo and the Parent Window is DashCommand followed directly by a symbol I can't read straight after and the parent window class is wxWindowNR, so I've tried:
LOAD;obd.skin;DashCommand;C:\Program Files(x86)\DashCommand\dashcommand.exe;!wxWindowNR
No change!
-autostart -startindashboards appear to work.
There is something in the support information about -title but I don't see what they mean, or why there is a colon in it???
I've also emailed PPE for help.
Cheers,
Dave
Right,
This run perfectly from desktop shortcut........
"C:\Program Files (x86)\DashCommand\dashcommand.exe" -title:"Dave One OBD" -startindashboards
I can't seem to get this to translate into RR though, prob easy if you know how, lol.
Right, I got this from PPE:
Is their a RR command I can add after the LOAD; command to make RR become foreground, thus getting rid of the ghosted image?I haven't tried to embed it into RideRunner myself. If you use -title, you need to put quotes around the title (or use no spaces in the title). For example:
-title Test
Window titled "Test"
-title Test 2
-title "Test 2"
Window titled "Test 2"
Our dashboards are 100% vector, they scale perfectly to any resolution. You shouldn't need to set any special resolutions for it to look good.
TIA,
Dave
I've found a workaround to use. I have put
LOAD;obd.skin;DashCommand;C:\Program Files (x86)\DashCommand\dashcommand.exe| -startindashboards -autoconnect;DashCommand
into the RideRunner ExecTBL file as part of the ONSKINSTART requirements, followed by ¦¦MAIN. This loads DashCommand and automatically reverts to MAIN MENU, thus having DashCommand ready for when the button is pressed or the command is spoken, as has been embedded properly as a result.
Thanks for your help, much appreciated.
Dave
Did you tested "RUNQ;...." on when your Skin starts?
And than if you load your screen, you have to show your application.
Just tried RUNQ again to make sure but DashCommand didn't preload....
Hi Dave,
I'm using dashcommand and the Carwings_Dynamic_Lite skin and the dynamic menu system.
I use the following command in the Menu.lst file.
DASHCOMMAND = "LOAD;DashCommand.skin;DashCommand;C:\Program Files\DashCommand\dashcommand.exe|-startindashboards -nosplash -title DashcommandForRR;DashcommandForRR",Dash Command, Icons\DashCommand.png
and just for completeness adding it to the skin is as simple as running ride runner, left clicking a button (I want to use to launch dc) until the list of available commands appears. Then look for the dash command item and select it.
away you go.
If you want to start dash command on riderunner startup then goto page2 under General in the RRConfig gui and enter this text in the text field under 'Start Command:'
any way just a bit more info for any one else looking.
thanks
Last edited by MalcolmC; 03-18-2013 at 10:08 AM. Reason: found the startup command
