Results 1 to 4 of 4
Thread: command for popup
    Aug 2007
    command for popup
    hello , the command for the menu popup close automatic only working in solid skin ? i try to put in transparent skin and dont working
    this command IDL,10
    thanks mikee
    MySQL Error
    Oct 2004
    well...
    thats an empty command
    IDL,10,"CANCEL"
    or
    IDL,10,"ESC"
    thats the proper use of the IDLE command, the deprecaited version is, "IDL,10" but then you need to have code in exctlb to process ONIDLE
    from history.txt
    + Screen Object Definition; IDLE - "IDL" additional option:
    ARGUMENT 2: is optional, this argument should be enclosed in quotes and is a command that will be executed
    when the idle time is exceeded. if this argument is not present, "ONIDLE" event is fired as usual.
    example: IDL,10,"CANCEL"
    This will execute "CANCEL" command after 10 seconds of IDLE.
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Aug 2007
    let me try
    Aug 2007
    WOWO ,work perfec with "CANCEL" perfect
    my friend , i find a scritp for the thermostat proyect what i talk to you , a find too a document with wifi module API , all command , how send you or post here ? thanks mikee
  1. Replies: 3
    Last Post: 11-07-2011, 04:24 AM
  2. LIST Command: Riderunner or skin command?
    By blazinlow in forum Road Runner
    Last Post: 10-23-2011, 01:28 PM
  3. popup with no BG
    By carputer1 in forum RR Skins
    Last Post: 09-22-2008, 02:16 PM
  4. Any way to get a popup message?
    By wysocki in forum Road Runner
    Last Post: 09-25-2007, 07:53 PM
  5. Popup LCD
    By it_shua in forum Hardware Development
    Last Post: 06-12-2005, 08:40 AM
