Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: when use RRCONFIG chinese cant display in any ini
    May 2011
    beijing,china
    since i used 2013 0101 RR, if i run rrconfig chinese in ini cant display who can help me thanks
    MySQL Error
    Oct 2004
    need more information, rrconfig itself is a application requiring .net 3.5sp1 and Administrative rights
    (it will ask for elevation)
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    May 2011
    beijing,china
    chinese display
    Quote Originally Posted by mitchjs View Post
    when i changed RRCONFIG or direct to edit ini all chinese cant display in ini files its messy code
    Dec 2008
    Quote Originally Posted by fuchengwu View Post
    I met the same issue with RR recent 2013 versions. The previous 2012 versions does not have this issue.
    My work around is to re-edit the Exectl.ini file with notepad manually, to correct the messy words with Chinese characters, then use "Save As...", select encoding as "Unicode" to save the ini file.
    MySQL Error
    Oct 2004
    if the file is Unicode to begin with, it should stay Unicode
    no changes to rrconifg, in a looong time...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Dec 2008
    It is really strange that the Exectl.ini will get messy with the Chinese characters once I run the RRconfig... Again, I did not have this issue when I use those 2012 versions RR.
    MySQL Error
    Oct 2004
    who knows... dam Unicode people
    start with a Unicode file
    im guessing, the file isn't Unicode
    most .ini files are ansi
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Dec 2008
    I'm sorry for I made a mistake in my previous descriptions, which per my bad memory. I re-confirmed this issue on my CarPC this morning. Here is the correction:
    1. Once run RRConfig, the Chinese words in my RR skin will get messy. By checking the "Exectbl.ini" file under DFX4.0 skins folder, the Chinese words in this file were all changed to strange characters, and the encoding of this file was changed to UTF-8.
    2. I manually edit the Exectbl.ini file with notepad, type in Chinese words in the file, then "Save As" the file with "ANSI" encoding. Then RR skin will display Chinese words correctly. Saving as "Unicode" doesn't work.
    3. Whenever run RR Config, the Exectbl.ini file will get messy again.
    MySQL Error
    Oct 2004
    you want to EDIT it, while in xxx
    saving it as ANSI, will save Chinese, but that's because that is your local
    which you can do, but then don't use RRCONFIG
    you should be able to edit in UTF-8
    worse case in UNICODE (UCS)
    EDIT IN UNICODE
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    looks like it will revert to ansi
    do this... STAY out of RRCONFIG!
    edit the files as UNICODE (little endian)
    RR supports, Unicode files for exectbl.ini
    (not sure on skin.ini)
    I got utf-8 on the mind from something else im working on
    go with UNICODE
    I don't think RRCONFIG will save back Unicode (yet)
    so stay out of rrconfig.... but switch exectbl.ini to Unicode
    and make sure RR is happy
    confirmed: General.ini, Exectbl.ini both support UNICODE
    SKIN.ini DOES NOT!!! (ill have to fix that at some point)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. RRconfig display size
    By jeepguy242 in forum Road Runner
    Last Post: 09-17-2012, 02:11 AM
  2. ilist ... Part of the Chinese display is still garbled~
    By aniceking in forum RR Bug Tracker
    Last Post: 09-24-2009, 08:36 AM
  3. Unable to display Chinese/Japanese/Korean tracks?
    By wywywywy in forum Road Runner
    Last Post: 08-23-2008, 06:45 AM
  4. Old RRConfig.exe
    By Jay_1.8t in forum Road Runner
    Last Post: 12-15-2007, 01:29 PM
  5. Replies: 0
    Last Post: 11-04-2005, 06:20 AM
