Results 1 to 10 of 12
Thread: may try w surface pro?
    Apr 2008
    so i just got the 128 gb for the specific purpose of installing in my car. Ive looked for a decent media player and the best that i see is actually ride/roadrunner. i think this will be a perfect fit, yeah?
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Yeah..but, will it install on that tablet?
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
    Jul 2009
    As long as RR runs on Windows 8 it should run on the surface pro.
    Maximum Bitrate Mickz's Avatar
    Sep 2009
    Australia
    Have you had a chance to try the screen in the vehicle? I will be looking at something like this in the future, however some testers have claimed the screen was quite reflective and difficult to use outside? Wonder what your thoughts are on this? I'm currently running Win8 on the car PC, runs perfectly.
    GA-Z77N-WIFI, i5-2400S, 8GB, Intel 520 128GB SSD, M4-ATX Modified, 2 Rev Cams, 2 Web Cams
    8" 16:9 TRANSFLECTIVE, Win8-64, Dual GPS RX and Garmin PC + Odyssey Nav, FM-DAB+, BB-Rec
    T-Screen HVAC control, custom microcontrollers, code and FE. CarPC Project
    Apr 2008
    no havent tried yet. im getting everything together to install in the next couple of weeks and never even thought about reflection issues yet. may rig something up this weekend to test.
    first two issues i have had though, my powermate or BU-353 dont recognize off the usb port. i may have to hit up seperate forums for that though
    Jul 2009
    I had to ditch my BU 353 because mine had the older USB to serial adapter which doesn't work with windows 8, I replaced it with a bluetooth gps I had.
    Apr 2008
    i think i may end up with a bt gps too. i have another alternative for the powermate, but id like to use that.
    VegasGuy's Avatar
    May 2009
    Las Vegas
    Quote Originally Posted by buckemdwn View Post
    The Windows 8 Prolific driver only supports the newer chipsets. However, you CAN use the older drivers with Win8 and they will work. Here's a link to one I have working with Windows 8 right now:
    http://repo.centrafuse.com/centrafus...ler_v1.5.0.exe
    Windows 8 will try to update that driver to the newer version, so if it stops working, open driver manager, right click on the affected port and rollback the driver to the previous version. There is supposed to be a way to indicate to Windows 8 that you don't want that driver automatically updated, but I haven't found it yet. Maybe the smart folks around here can give us a tip.
    VegasGuy
    Jul 2009
    I did the driver thing but windows updated the driver and I didn't feel like doing the rollback every time. It would nice to not have Windows 8 update that driver. The one nice thing about the bluetooth GPS is that it has a battery in it and will startup with a connection request and disconnect after a period of no activity. I wired up a nice charger for it too.
    Sep 2009
    Australia
    Quote Originally Posted by VegasGuy View Post
    VegasGuy
    +1 , I had to do the same thing a few weeks ago. Apart from that I have over 16 USB devices running (3 are Prolific) and everything is perfect.
    Very easy to stop windows 8 auto updating the drivers. Goto Start and select Settings for the Search function and type in "change device" and select "Change Device installation settings".
    EDIT:
    Another way to get access to every setting is the old "GOD folder" trick. Create a shortcut on the Desktop and paste the following as the location %WinDir%\explorer.exe shell:::{F90C627B-7280-45db-BC26-CCE7BDD620A4}
  1. Microsoft Surface Tablets
    By bblitz in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 09-05-2012, 08:19 AM
  2. Surface Acoustic Wave SAW
    By ssteger in forum VaultWiki
    Last Post: 10-19-2009, 01:39 PM
  3. PSU Surface Placement Question.
    By HiJackZX1 in forum Power Supplies
    Last Post: 07-27-2008, 11:24 AM
  4. All about Microsoft Surface
    By add1 in forum General Hardware Discussion
    Last Post: 10-11-2007, 08:34 AM
  5. JUST RELEASED: Microsoft Surface
    By DJiK in forum General MP3Car Discussion
    Last Post: 05-30-2007, 09:05 PM
