Results 1 to 5 of 5
Thread: Variables in the skin.ini and ||
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Into my skin.ini file, i define 4 variables as :
    Timer1CMDOn=x10sendplc;on;e1||x10sendplc;dim;e1;50
    Timer2CMDOn=x10sendplc;on;e2||x10sendplc;dim;e2;50
    Timer3CMDOn=x10sendplc;on;e3||x10sendplc;dim;e3;50
    Timer4CMDOn=x10sendplc;on;e4||x10sendplc;dim;e4;50
    But into the skintool, the VAR Timer1CMDOn return me Timer1CMDOn=x10sendplc;on;e1 and not Timer1CMDOn=x10sendplc;on;e1||x10sendplc;dim;e1;50 !
    My goal is to create 4 command that i can edit into the skin.ini file !
    I don't want to use the exectbl.ini because i can't edit my commands by my plugin !
    It's normal or it's a RR issue ?
    MySQL Error
    Oct 2004
    I don't think that is the ideal usage of user vars to put commands in them
    the parser prob will split em... as you seeing
    you could use ++
    and since its your plugin, work it yourself
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Aug 2007
    my friend pierrotm777 i test that command and working fine the light turn on and the same moment down the intensity to 50% , working fine
    May 2008
    Bordeaux, France
    Quote Originally Posted by mitchjs View Post
    you could use ++
    In my plugin , i can replace the || by ++ and use the SDK.Execute("CMD1++CMD2") ?
    Or Use the ++ just into the skin.ini file and into my plugin replace the ++ by || before the SDK.Execute command ?
    May 2008
    Bordeaux, France
    Quote Originally Posted by mikeeps2 View Post
    Yes in manual but not through the plugin :-) !
  1. Incrementing variables
    By JiC in forum FB Software
    Last Post: 12-22-2008, 12:11 AM
  2. Dividing variables
    By frangolfgt in forum Road Runner
    Last Post: 07-19-2007, 08:30 PM
  3. variables??
    By liquid_smoke in forum Road Runner
    Last Post: 06-07-2006, 03:44 PM
  4. How do I use Variables on my Skin ?
    By guino in forum RR FAQ
    Last Post: 06-07-2006, 11:51 AM
  5. PHP...not reading url variables...
    By PoBoy in forum Off Topic
    Last Post: 09-16-2002, 10:53 PM
