Results 1 to 8 of 8
Thread: RR 04-01-2013 Release
    MySQL Error
    Oct 2004
    SPRING? Could have fooled me...
    (ok today was nice (4/5/2013))
    Download HERE
    Not too much
    a bug, and a new RR Variable...
    HISTORY:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    3/21/2012
    # Fixed slider POINTER image scaling when scaling skins
    + Uservar; RRStatus. Values are, 1 = Stop, 2 = Play, 3 = Pause, 4 = Muted, 5 = UnMuted, 0 = Unknown
    3/8/2012
    + Added unicode support for skin.ini file
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Add the unicode option was a good initiative ! Thanks
    Oct 2004
    Atlanta, GA
    I cant seem to find the download link. Is it currently unavailable?
    Lexus SC300:
    Shuttle SB65G2/P4 2.4GHz/512 Meg RAM/120G Drive/Dynamix 706 TS/M4-ATX PSU/Rikaline 6010 GPS/RR/iGuidance 4
    Corvette:
    VIA EPIA SP-13000/512Meg RAM/250G drive/M1-ATX PSU/Xenarc 7" TS/BU-353 GPS/RR/iGuidance 4
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    It's there - where it's always been.
    Got my copy...
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Having an issue with this version. Updated RR and now it won't load skins. Tried Carwings and DFX5. Debug.txt below
    Code:
    04/30:
    20:39:01.938: Start -- Version: 4/1/2013
    20:39:01.938: OS Type: Windows 7
    20:39:01.938: FileManager: FileMode = Profile
    20:39:01.938: FileManager: mypath = C:\Program Files\RideRunner\
    20:39:01.938: FileManager: ProfilePath = C:\Users\AUDIO\Documents\RideRunner\
    20:39:02.016: Start Sequence: Starting Player...
    20:39:02.016: PLAYER: Initialization creating object
    20:39:02.016: Winamp AudPlayer---> Attempting start of winamp.exe
    20:39:02.078: Winamp AudPlayer---> waiting for window handle
    20:39:02.289: Winamp AudPlayer---> winamp.exe started: v20577
    20:39:02.289: PLAYER: Started
    20:39:02.289: PLAYER: Winamp Version: 5.61
    20:39:02.289: PLAYER: Initialization complete
    20:39:02.289: Start Sequence: Starting Radio Device...
    20:39:02.297: Start Sequence: Starting Serial Devices...
    20:39:02.297: Start Sequence: Starting Mixer...
    20:39:02.367: VMC---> Set object successful
    20:39:02.367: VMC---> SourceLine Count: 1
    20:39:02.375: VMC---> SOURCE: Mixer line #1: "Speakers"
    20:39:02.375: Start Sequence: Starting Speech...
    20:39:03.102: DirectDraw Count: 2 - [] [{67685559-3106-11D0-B971-00AA00342F9F}]
    20:39:03.148: INFO: LoadSkinVars() - Reading data from C:\Users\AUDIO\Documents\RideRunner\Skins\DFX5\skin.ini
    20:39:03.156: Plugin Manager: loading Global Plugins...
    20:39:03.164: Plugin Manager: Plugin Found: InetRadioLabels
    20:39:03.164: Plugin Manager: Plugin loaded (Global): InetRadioLabels
    20:39:03.172: Plugin Manager: Plugin Found: RRExtended
    20:39:03.172: Plugin Manager: Plugin loaded (Global): RRExtended
    20:39:04.453: Plugin Manager: Plugin Found: RRMediaDB
    20:39:04.453: Plugin Manager: Plugin loaded (Global): RRMediaDB
    20:39:04.586: Plugin Manager: Plugin Found: RRPandora(.NET)
    20:39:04.586: Plugin Manager: Plugin loaded (Global): RRPandora
    20:39:04.797: Plugin Manager: Plugin Found: SkinTool
    20:39:04.797: Plugin Manager: Plugin loaded (Global): SkinTool
    20:39:04.797: Plugin Manager: Plugin Found: Weather
    20:39:04.797: Plugin Manager: Plugin loaded (Global): Weather
    20:39:04.805: Plugin Manager: loading Global Plugins Completed.
    20:39:04.805: LoadSkin: C:\Users\AUDIO\Documents\RideRunner\Skins\DFX5\
    20:39:04.836: INFO: LoadSkinVars() - Reading data from C:\Users\AUDIO\Documents\RideRunner\Skins\DFX5\skin.ini
    20:39:04.844: Plugin Manager: loading SkinDir Plugins...
    20:39:04.844: Plugin Manager: Plugin Found: DFX5
    20:39:04.844: Plugin Manager: Plugin loaded (SkinDir): DFX5
    20:39:04.891: Plugin Manager: loading SkinDir Plugins Completed.
    20:39:04.891: ERROR: Sorry without GDI+ (Fastmode=-1) .png Not Supported (menu_OFF.png)
    20:39:04.945: Global Hotkey: Successfully registered keycode:2112
    20:39:04.945: ERROR: Sorry without GDI+ (Fastmode=-1) .png Not Supported (menu_On.png)
    20:39:04.953: ERROR: Loading image file(s) for: menu.skin (Invalid picture)
    20:39:04.953: Start Sequence: C:\Users\AUDIO\Documents\RideRunner\Skins\DFX5\ does not contain a valid skin!
    20:39:06.289: Shutdown: (1)
    20:39:06.289: Shutdown: (2)
    20:39:06.297: Shutdown: (3)
    20:39:06.297: Shutdown: (4)
    20:39:06.297: INFO: SaveResume() - Saving resume data to C:\Users\AUDIO\Documents\RideRunner\Cache\resume.ini
    20:39:06.297: INFO: LoadResume() - Reading resume data from C:\Users\AUDIO\Documents\RideRunner\Cache\resume.ini
    20:39:06.297: Plugin Manager: Warning Plugin inetradiolabels does not support Terminate Method
    20:39:06.297: Plugin Manager: Warning Plugin rrextended does not support Terminate Method
    20:39:06.297: Plugin Manager: Warning Plugin rrmediadb does not support Terminate Method
    20:39:06.375: Plugin Manager: Warning Plugin skintool does not support Terminate Method
    20:39:06.375: Plugin Manager: Warning Plugin weather does not support Terminate Method
    20:39:06.375: Plugin Manager: ALL Plugins unloaded.
    20:39:06.422: Shutdown: (5)
    20:39:06.422: Player is running
    20:39:06.422: Winamp AudPlayer---> Closing...
    20:39:06.422: COMReceive: RM_Exiting
    20:39:06.430: SDK command: RM_Exiting
    20:39:06.547: Winamp AudPlayer---> Closed
    20:39:06.547: Shutdown: (6)
    20:39:06.547: Shutdown: (7)
    20:39:06.547: OSUnloadMode: 1
    20:39:06.547: Global Hotkey: All keys unregistered
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    You have fastmode=-1, so any skins with .png graphics wont work. Open RRConfig and on the first place set Screen Fast Mode to GDI+
    Quote Originally Posted by Dougw133 View Post
    Code:
    04/30:
    Live mp3Car Facebook Chat
    May 2008
    Bordeaux, France
    9/24/2011
    + Skin command; "RRGetOption"
    + Skin Command; "RRSetOption"
    + Skin Command; "RRGetPath"
    + Skin Command; "RRGetFile"
    Please , what these commands do ?
    RR return me 'Command Not Executed: RRGetOption'
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Thanks.
  1. 2013 Ultima Can Am - PC Install
    By 356Speedster in forum Worklogs
    Last Post: 05-15-2013, 06:32 PM
  2. RR 03-01-2013 Release
    By mitchjs in forum Road Runner
    Last Post: 04-01-2013, 01:12 PM
  3. RR 02-01-2013 Release
    Last Post: 03-03-2013, 01:00 PM
  4. RR 01-01-2013 Release
    Last Post: 01-02-2013, 01:16 PM
  5. 2013 : is this the year, finally?
    By SapporoGuy in forum Software & Software Development
    Last Post: 12-31-2012, 07:43 PM
