Results 1 to 8 of 8
Thread: Is CMD DELAYEXEC with 0.5s possible?
    Sep 2012
    Germany - Munich
    i want to use the command DELAYEXEC with 0.5 seconds.
    Example: DELAYEXEC;0.5;CMDWHATEVER
    Is it possible to get this feature?
    i tried with 1 -> works; 2 -> works; 2.1 -> works too.
    but values smaller 2 with included dot, don't work.
    i'd like use Delayexec, because WAIT is bad. if WAIT is activ, RR don't accept any other commands at this time. and scrolling Labels are freezing during wait.
    MySQL Error
    Oct 2004
    nope, looking at code
    If Val(dt(1)) >= 1 Then
    not sure exactly how the command works, ill see if .x is possible
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    MySQL Error
    Oct 2004
    ok, the timer runs at 1 sec
    so each number delays 1 sec
    so delayexec of 1 is 1 sec (prob turns out to be + .1)
    also any right of decimal point values would cause the command not to work at all
    due to a "bug" in the code (actually never expected anyone to use a decimal number)
    so
    DELAYEXEC;2.1;AUDIO
    would never run...
    that is easily fixed
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Sep 2012
    Germany - Munich
    does it mean, you will fix the code, and it is no longer possible to use decimals with dot?
    MySQL Error
    Oct 2004
    I will fix the code to drop anything decimal
    so 2.1 becomes 2, 3.5 becomes 3
    it never could of work in decimals, its running inside a 1 second timer
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Sep 2012
    Germany - Munich
    ok
    changing the timer isn't possible or to much effort?
    MySQL Error
    Oct 2004
    much effort...
    and not sure any real benefit
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Sep 2012
    Germany - Munich
    ok
