Results 1 to 6 of 6
Thread: Pandora problem??????
    Maximum Bitrate locs4dayz's Avatar
    Sep 2009
    Philadelphia, PA
    when RR loads up....i get a message saying no credentials found for pandora....how do i fix????
    Linux(Learning the curve...Like when driving!!!)
    Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by locs4dayz View Post
    Enter your Pandora credentials? lol
    -Start RR in carwings (to be sure needed skins are there)
    -Go to Plugin Manager
    -Click RRPandora in the list
    -Click Settings
    -Enter username/password on the settings screen.
    -Save
    If that doesn't fix the issue its very possible Pandora changed their code again and the plugin is buggered so deactivate it (move it out of the plugins folder)
    Live mp3Car Facebook Chat
    Sep 2009
    Philadelphia, PA
    Quote Originally Posted by Sonicxtacy02 View Post
    -Click Settings
    -Save
    did what u said....now i can create stations...but nothing seems to be playing...how do i fix????
    Woodbridge, VA
    Blog Entries
    55
    Do you have winamp installed? What version? The plugin requires winamp to play audio. Are the stations you created showing up in the list on rrpandora screen?
    Sep 2009
    Philadelphia, PA
    i use wmp....but i'm installing winamp just for pandora.......just need to figure out how to set it up
    Woodbridge, VA
    Blog Entries
    55
    winamp shouldn't require much configuration to get rrpandora to work. Just install and you should see a winamp instance start when RR starts. The code that controls winamp is a .dll that Mitch created for his webradio app.
  1. Pandora!!!!!
    By Mr_DJT in forum Apple iPad
    Last Post: 09-11-2011, 09:31 PM
  2. Pandora
    By jnot2 in forum OpenMobile
    Last Post: 12-07-2010, 07:37 PM
  3. Is the Pandora a good car pc?
    By Heather in forum Open Source Hardware
    Last Post: 11-17-2010, 10:43 PM
  4. Pandora MP915-B barebones xp install problem
    By zed0 in forum General Hardware Discussion
    Last Post: 02-07-2007, 08:03 AM
  5. IR hack for Pandora?
    By st_abbott36 in forum Hardware Development
    Last Post: 12-25-2006, 12:59 PM
