Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: 2 Issues with a fresh instal of RR
  1. #11
    MySQL Error
    Oct 2004
    here is some info for you....
    fix your skin!!
    01/21/2012
    * Skin Indicator; "heading" changed to "RRGPSHeading"
    + Skin Label; "RRGPSHeading" shows "N", "NE", "E", "SE", "S", "SW", "W", "NW"
    RRGPSHeading indicator has a path to file
    for example
    so... go to you skin, and find all "HEADING2" and change to "RRGPSHeading"
    and put all the images in the skinpath....
    with the right naming N.jpg, NE.jpg...etc
    oh and NA.jpg too
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #12
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    GpsIndFix is now a part of the Bluezx3's RRExtended plugin , so you need to install this very cool plugin !
    = GpsIndFix Sect =
    Description
    Allows usage of additional GPS heading Indicator images to show both dir & Sat count all in one indicator
    The ind will indicate the Signal strength by changing the ind color by the number of satellites,
    meaning...weak(1-4), fair(5-6), good(7+)
    Ini Settings
    (rr.ini or skin.ini)
    GPSIndFolder=xxxx -(optional) Specifies a folderName inside a skin's folder that will be used for the indicator images,
    if not specified, will use the 'Heading Inds' folder in the plugin's folder for the images
    GPSIndFix_Enabled=(True/False) -Enables or disables this feature
    Commands
    None
    Labels
    None
    Indicators
    "HEADING2" -Name of indicator to show the GPS DIR &/or Signal Strength
    Addition Notes
    Accepts either jpg or png file extions, it will use whichever extention is on the N.xxx/N_1.xxx ind graphi
    ****How to use the indicator*****
    To use the signal strength you must have the additional indicator graphics. These new
    graphic indicator file names are the direction(N,NE,E,SE,S,SW,W,NW) followed by a _x.(jpg/png),
    where x is 1-3 using the above as the guide lines. So "N_1.png" would be north with a weak signal
    where as "SE_3.png" would be southeast with a good satellite signal.
    Sample indicators are included in the 'Heading Ind' folder (iG style)
  1. Difficties with RR instal
    By averagewonder in forum Road Runner
    Last Post: 12-31-2012, 04:41 PM
  2. Custom LCD instal HELP!!!
    By rudels in forum Fabrication
    Last Post: 03-20-2007, 11:09 AM
  3. About to instal 1.6
    By thrmaln in forum Centrafuse
    Last Post: 03-16-2006, 05:35 PM
  4. AUDI A4 My second instal :)
    By ThEScReW in forum Show off your project
    Last Post: 02-26-2006, 08:34 PM
  5. lilliput instal
    By defender90 in forum MacCar
    Last Post: 07-12-2005, 01:38 PM
