Results 1 to 10 of 12
Thread: 2 Issues with a fresh instal of RR
    Variable Bitrate rizaydog's Avatar
    Nov 2007
    North Central PA
    I just installed the newest version of riderunner. I am using a modified BMV skin. I have everything working except two things...
    1. I have the gps working fine. I use i guidance for navigation. I have speed, altitude, lat and longitude displayed on the skin and working fine. On the main screen, I have an area that shows the current city and zip code from the gps. Before updating RR, this worked great. I placed the zips.dat into the new RR folder. Does it need to go somewhere else? Am I forgetting something?
    2. Previously working with the older version was the indicators. However, after installing the newst version, I can't get them to work. I have the indicator folder in my skin folder as before. I placed a copy in the riderunner folder as well. I installed the GPSIndFix and that didn't help. With the old RR, I needed to add GPSIndFolder=Indicators and GpsIndFix_Enabled=true into the rr.ini to make it work. I can't find a rr.ini in this new version.
    Any help with these would be greatly appreciated.
    I told my psychiatrist that everyone hates me. He said I was being ridiculous - everyone hasn't met me yet .
    MySQL Error
    Oct 2004
    RR doesn't use zips.dat at all, there is a plugin, called GPS 2 City.... https://dl.dropboxusercontent.com/u/....1%20Setup.exe
    I have no idea what gpsindfix is... I surmise its not needed... but you might have a plugin corrupting indicators...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Nov 2007
    North Central PA
    Thanks Mitch. That worked. I forgot to reinstall the gps2city.
    The gpsindfix was needed on the older version to get these indicators working. Also, the old rr had a rr.ini file. I can't seem to find this in the new version... Anyway, you would add GPSIndFolder=Indicators to show the folder of indicator images and GpsIndFix_Enabled=true into the rr.ini.
    Since I can't find the rr.ini file, I can't add these lines. Any idea's where this file is located now?
    Mar 2010
    You should find rr.ini in My Documents..
    i.e. this is my path to the RR config files..
    C:\Documents and Settings\davekra\My Documents\RideRunner\Config
    Nov 2007
    North Central PA
    Thanks for your help. I will check my doc after work.
    This morning on my way to work I noticed that the city didn't change automaticaly as I drove around. If I clicked on the area where I placed the city and zip on my skin, it did update to the current city. However, as I drove, it changed to another town 20 miles away... Something is goofy with it.
    Nov 2007
    North Central PA
    I decided to investigate the incorrect city showing up. I looked into the gps2city folder and found the zips.dat file. It was about half the size of the one I previously was using. I made a copy of the original gps2city zips.dat file and added my previously used zips.dat file to the gps2city folder. When I restarted rr, the correct city showed. I'll keep testing it for a few days to make sure that was the problem.
    Now to figure out how to get these indicators working...
    Nov 2007
    North Central PA
    Now that I found the rr.ini, I got the indicators working by adding the lines: GPSIndFolder=Indicators and GpsIndFix_Enabled=true. Now I am getting a popup, GPSIndFix Run-time error '13': Type mismatch, every time rr starts. I am guessing the GPSIndFix is not compatible with the new version of rr. I uninstalled it and the indicators stopped working. I then reinstalled it and, after getting the popup, they worked again.
    Is there a newer version of the GPSIndFix available or some way to remove that popup?
    MySQL Error
    Oct 2004
    I don't know anything about that gps fix, never heard of it till now
    and why do you even need it?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Nov 2007
    North Central PA
    GPSFix is used with blue ZX3's indicators. I used it for years with my old version of rr without issue. Now with the updated version, I am getting the pop up. The indicators don't seem to work at all unless I use the fix and GpsIndFix_Enabled=true in the rr.ini file.
    MySQL Error
    Oct 2004
    what indicators don't work?
    I don't know of any blue ZX3's Indicators....
    my advice would don't use the GPSFix, and solve the actual problem
    nothing is known to me about indicators that don't work...
    a plugin can destroy an indicator (bad programming, or even intentional)
    course I have no idea what you got in your system, you could ATTACH a debug.txt
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Difficties with RR instal
    By averagewonder in forum Road Runner
    Last Post: 12-31-2012, 04:41 PM
  2. Custom LCD instal HELP!!!
    By rudels in forum Fabrication
    Last Post: 03-20-2007, 11:09 AM
  3. About to instal 1.6
    By thrmaln in forum Centrafuse
    Last Post: 03-16-2006, 05:35 PM
  4. AUDI A4 My second instal :)
    By ThEScReW in forum Show off your project
    Last Post: 02-26-2006, 08:34 PM
  5. lilliput instal
    By defender90 in forum MacCar
    Last Post: 07-12-2005, 01:38 PM
