Results 11 to 20 of 23
Thread: Music stays on "original" song forever will not resume to last song played
  1. #11
    Variable Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    Quote Originally Posted by mitchjs View Post
    just copy them out of the plugins folder to really remove em...
    remove all but dfx, skintool, rrextended.
    for the hell of it try winamp alone
    Removed the plugins and still the same problem.
    Tried winamp alone and it works correctly.
    Back to the drawing board.
    Win 7 Pro 64bit, 4gb DDR2 Ram, q6600 Processor, Solid state drive & 7200 drive, Andrea mic, Sirius, DE HD Radio, Opus power supply, 10.4" touchscreen.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    2.) Sets Orion Components - P-SERIES
  2. #12
    MySQL Error
    Oct 2004
    something in your skin... review exectbl.ini (both global and skin)
    did you review debug.txt... near rr exit...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #13
    Feb 2005
    Huntsville, AL
    I tried winamp 5.64 with no luck
    I will look into the exectbl.ini to see i I can figure out anything.
    Here is a copy of my debug.
    Mitch do you (or anyone else) have a copy of their debug running DFX so I can compare or if anyone can see a problem with my debug?
    Attached Files Attached Files
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  4. #14
    MySQL Error
    Oct 2004
    try commenting out all that quit crap in the exectbl.ini
    lines 19 & 20
    "QUIT"
    "ONEXIT"
    that
    don't think its it, cause mine has all that...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  5. #15
    Feb 2005
    Huntsville, AL
    lines 19 & 20
    "QUIT"
    "ONEXIT"
    that
    Seems like that fixed it.
    I tried it about 6 times and it is working.
    The funny thing is half of the 6 times I can see the name change back to the original song right before it closes like it did before but then it works correctly once I restart the computer
    Like I said before I have had this problem for the longest time for a good couple years or so. I have done multiple clean installs and that problem was still there even on different computers. Not sure why yours worked good and I haven't seen anyone else with this type of problem.
    But anyways thanks for helping me out on this.
    I just got tired hearing the same song over and over all this time.
    Michael
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  6. #16
    MySQL Error
    Oct 2004
    well.. now u need to narrow down exactly what in the those two lines is doing it!!!!
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #17
    Feb 2005
    Huntsville, AL
    These are the 2 lines I put / in front of:
    "QUIT","END_CMD"
    "ONEXIT","BYVAR;FINAL_QUIT;END_CMD<<"
    The one that is causing the problem is the bottom line "ONEXIT","BYVAR;FINAL_QUIT;END_CMD<<"
    I tried one line at a time and the other line works by itself. I have no idea what it means but just thought i would point it out.
    I think it's about time for someone to go through the DFX code and fix any errors. I wonder who could do that....
    "Did you test it in DFX 6.0??"
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  8. #18
    MySQL Error
    Oct 2004
    see I have untouched dfx5 code, and I don't have the problem...
    attach the exectbl.ini
    DFX5 does a lot on its exit...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #19
    Feb 2005
    Huntsville, AL
    here is the file
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
  10. #20
    MySQL Error
    Oct 2004
    I don't see anything that jumps out
    try this... take a look what I did... thinned it out...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Replies: 6
    Last Post: 02-06-2008, 11:37 AM
  2. Question:Custom Currently Played Song Indicator.
    By EL CAMINO in forum RR Skins
    Last Post: 05-09-2007, 09:36 PM
  3. Replies: 8
    Last Post: 05-02-2007, 04:00 AM
  4. Sirius "special" "I-like-this-song" button ?
    By jeep642 in forum Road Runner
    Last Post: 12-28-2006, 11:36 AM
  5. "all music" mode takes forever and a day to load?
    By miztahsparklez in forum FrodoPlayer
    Last Post: 03-12-2005, 05:22 PM
