Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Music stays on "original" song forever will not resume to last song played
    Variable Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    Let me try to explain this without confusing you more
    If I select any music playlist and it starts playing a song. That exact song plays over and over every time I start up the car. Yes I played different songs before shutting off the car
    If I select a different playlist than a different song plays but then that song will play over and over every time I start up the car.
    What I have found out is if I close RR manually it works correctly.
    How can I get it to work correctly just shutting off the car?
    I am using a Opus 320w Power supply which shuts down and starts up the computer automatically.
    When I shut off the car and watch the shut down process I can see RR changing the song back to the original song before it finishes shutting down.
    Any ideas?
    Attached Files Attached Files
    Win 7 Pro 64bit, 4gb DDR2 Ram, q6600 Processor, Solid state drive & 7200 drive, Andrea mic, Sirius, DE HD Radio, Opus power supply, 10.4" touchscreen.
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    2.) Sets Orion Components - P-SERIES
    MySQL Error
    Oct 2004
    maybe its winamp...
    see you don't know how Opus 320w Power shuts down the system..
    lets assume, it sends a message to shutdown...
    which means, windows will start closing apps...
    and winamp MAY be closed before RR
    I that case, RR would use the last known, playlist position
    and save that into resume.ini
    so what I would do, is don't let RR start automatically on boot...
    load a playlist (SMALL ONE, no more then say 20 songs), play song 5...
    shutdown via the opus
    power back on
    and look at resume.ini, is it right?
    ie is the timestamp right? then its contents... the PL position
    hell it could even be a winamp plugin, remove all plugins in winamp
    if any...
    oh and simplify the RR, test with carwings...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Feb 2005
    Huntsville, AL
    Quote Originally Posted by mitchjs View Post
    maybe its winamp...
    power back on
    if any...
    The Opus is hard wired into the power button on the mombo and case. It just triggers whatever is setup in Windows for the power button. I have it setup to shut down the computer.
    I did more testing and this is what I have found out.
    In carwings it seems to be working.
    It seems to be related to the DFX skin or Windows?.
    If I shut down RR with the DFX skin manually through the DFX skin it works correctly. If I shut down windows through the DFX skin it still works correctly.
    It does not work correctly if I press the power button on the case (which is set to shut down the computer)
    I am confused by when it is closed by Windows (using power switch) it does not work but then it works correctly if I manually close RR through the DFX skin or shut down Windows through the skin.
    Any ideas on how to fix it?
    Is there any way in Windows or RR to manually assign the shutdown procedure of the open programs?
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    Oct 2012
    Shutdown Manager
    Quote Originally Posted by michaelrj9 View Post
    The Opus is hard wired into the power button on the mombo and case....
    Sounds to me as if what could be happening is you have a short timer at shutdown and your Windows settings may be set to force shutdown. Are you clearing the page file at shutdown? Try not doing that if you are (doing that can slow down the shutdown process quite a bit).
    Regardless, try a Google search for 'windows XP shutdown manager.' I don't recall if it's OK to post 3rd party links for products on here or not, so I won't. But you can find a range of free and small-fee products online that purport to do this. Otherwise, I'd suggest checking your Windows Registry shutdown parameters. See if you can extend the time the PC has to shut down all processes, and lengthen the time before it forces a shutdown.
    There's a partial guide here. Keep in mind you would want to do the opposite of what this author recommends (i.e. lengthen the shutdown time, versus shorten it):
    http://www.howtogeek.com/80102/make-...down-faster-2/
    OR
    You could modify the registry setting to force Windows to always hibernate instead of shutting down when it gets a shutdown command.
    http://technet.microsoft.com/en-us/l.../cc962586.aspx
    Unless someone else has a better idea, I'd try these things and see if they help.
    Good luck!
    RN
    MySQL Error
    Oct 2004
    ids say has nothing to do with windows shutdown
    but all in DFX
    going to be very hard to solve
    windows will shutdown, applications in any order, if it kills winamp 1st, that's ok, RR knows how to deal with that
    it might all be that dfx, is saving the last audio, and its loosing track...
    not sure if your're using RRMEDIA with dfx, not sure even if that can affect your issue
    but I can tell you, its porb only you who can solve
    I think I have dfx installed, I could try rr with dfx, then push my power button...and see what happens
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    results, using the latest RR, the latest DFX5.1 (said no updates when I did a check)
    using Winamp 5.63 WITH NO PLUGINS installed in WINAMP!!!!
    I went to music, picked an album using standard browser, then in playlist screen
    switched to the 4th song, went about 1 min in, while sitting right there.
    pressed the power button...
    computer shutdown...
    walked away...
    came back 5 mins later
    started PC
    logged in...
    and opened RR
    and it went to DFX main menu, playing EXACTLY where I left off
    so I say it works perfectly
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Feb 2005
    Huntsville, AL
    walked away...
    started PC
    logged in...
    and opened RR
    mitch
    I made a little progress.
    Here is a video of what it does right before it shuts down (the last couple seconds)
    I have all the different RR plugins I use disabled except for RRExtended RRMedia & DFX plugin. I (also had RRMedia disabled at one time too and that did not help either)
    Right now I am using Winamp 5.63 with no plugins installed except the ones that come pre installed. I also tried 5.62 with no luck. I have not tried 5.64 yet. I know I have had this problem for a while like probably a couple years or so.
    What I tried is I used Windows Media player. I only tried it a 2 times but it worked those 2 times. Need to try it more to make sure it stays working.
    So my question is is there any benefit one over the other with Winamp or Windows Media Player?
    Do I need to do anything with the media player to make sure I get my whole music collection?
    And the last question is WHY does it mess up with Winamp and the DFX skin?
    1.)Orion 2500d Amp
    1.)Orion 15" h2 Sub
    1.)Orion 8004 Amp
    MySQL Error
    Oct 2004
    one thing, just because it says disabled, doesn't fully mean disabled... its a partial disable...its up to the plugin to actually disable...
    I got a bunch of plugins myself (12 to be exact, 99% I wrote)... but if you want, you can just copy them out of the plugins folder to really remove em...
    remove all but dfx, skintool, rrextended... and see how it goes
    (just copy out of plugins folder)
    like make a folder called plugins disabled, and move them there
    for sure I saw it jump to song 1... just before shutdown
    something is doing that on purpose!!!
    you have to elim, till you figure it out
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    for the hell of it try winamp alone
    run it, load a bunch of songs, go to the middle of the list of songs... play, and shutdown...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Replies: 6
    Last Post: 02-06-2008, 11:37 AM
  2. Question:Custom Currently Played Song Indicator.
    By EL CAMINO in forum RR Skins
    Last Post: 05-09-2007, 09:36 PM
  3. Replies: 8
    Last Post: 05-02-2007, 04:00 AM
  4. Sirius "special" "I-like-this-song" button ?
    By jeep642 in forum Road Runner
    Last Post: 12-28-2006, 11:36 AM
  5. "all music" mode takes forever and a day to load?
    By miztahsparklez in forum FrodoPlayer
    Last Post: 03-12-2005, 05:22 PM
