Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: RR 09-01-2013 Release
    MySQL Error
    Oct 2004
    Back to School folks!
    Download HERE
    couple really little things in this release
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    9/3/2013
    + Skin Label "RRTRACKEXT" displays current track (audio/video) file name extension in upper case.
    8/9/2013
    # Fixed Incorrect math in SetTrackPosition for Foobar2k Player
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Thank you Mitch! Peace & Rush be with you!
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Thanks for this new release mitchjs
    Jun 2011
    PA
    Thanks mitch! We appreciate all the hard work!
    Mar 2011
    embededd program does not work.
    add name program to start but when you start the application process selected RR will not start.
    you are aware of this BUG?
    MySQL Error
    Oct 2004
    im going to play dumb here, but how are you starting the application
    off the top of my head, there is no feature to start an application when rr starts
    (but I don't use rr enough daily to remember all its 100s of features)
    you can of course do it, with some skincode
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Mar 2011
    I know how to do it, I'd say thank you.
    May 2008
    Bordeaux, France
    mitchjs,
    Is possible to a an option to the IDL screen function ?
    As that exist for the TMR feature, i should like to have an command when the IDL value is done !
    ex:
    IDL,5,"MYCOMMAND"
    Thanks !
    MySQL Error
    Oct 2004
    that should be there, read history... like I said I cant remember all the stuff rr does
    im too old!
    the who idea is to use less, exectbl.ini
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Jun 2011
    PA
    Quote Originally Posted by pierrotm777 View Post
    mitchjs,
    ex:
    IDL,5,"MYCOMMAND"
    Thanks !
    This is from History
    2/21/2011
    + Screen Object Definition; IDLE - "IDL" additional option:
    ARGUMENT 2: is optional, this argument should be enclosed in quotes and is a command that will be executed
    when the idle time is exceeded. if this argument is not present, "ONIDLE" event is fired as usual.
    example: IDL,10,"CANCEL"
    This will execute "CANCEL" command after 10 seconds of IDLE.
    + Screen Object Definition; TIMER - "TMR" additional option:
    when the timer expires. If this argument is not present, "ONTIMER" event is fired as usual.
    example: TMR,5,"PlaySound;$SKINPATH$Sounds\Click.wav"
    This will play the click.wav sound every 5 seconds.
  1. RR 08-01-2013 Release
    By mitchjs in forum Road Runner
    Last Post: 08-06-2013, 11:11 AM
  2. RR 06-01-2013 Release
    Last Post: 08-03-2013, 09:06 PM
  3. RR 05-01-2013 Release
    Last Post: 05-15-2013, 08:58 AM
  4. RR 04-01-2013 Release
    Last Post: 05-02-2013, 03:42 PM
  5. RR 01-01-2013 Release
    Last Post: 01-02-2013, 01:16 PM
