Results 1 to 6 of 6
Thread: Don't get ONSONGSTART after NEXT
    Sep 2012
    Germany - Munich
    Hi
    I don't get the cmd ONSONGSTART after NEXT. only on RR startup or switching between sources fires ONSONGSTART.
    Is there a bug?
    MySQL Error
    Oct 2004
    I DO!
    use skintool
    could be trapped by a plugin too... consider removing all plugins (except skintool)
    or trapped by exectbl
    test with carwings
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Sep 2012
    Germany - Munich
    Did a test. All Plugins were disabled.
    and ONSONGSTART in exectbl.ini to /ONSONGSTART
    only after sourcechange
    MySQL Error
    Oct 2004
    how did u disable plugins?
    (only true way, is copy them out of the plugins folder(s))
    and did u test with carwings?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Sep 2012
    Germany - Munich
    yes, i removed the plugins from plugin folder.
    in car wings is the same result.
    Sep 2012
    Germany - Munich
    some news
    ONSONGSTART work only with RR accepted id3-tag.
    Can you fix this, that it runs with an empty setting?
    Because, not all of my files have an good id3 tag. the filename is the information for me.
  1. Check when RR send a ONSONGSTART command with autoit
    By pierrotm777 in forum Road Runner
    Last Post: 11-01-2011, 10:40 AM
  2. OnSongStart
    By Valheru in forum Road Runner
    Last Post: 09-18-2009, 04:02 PM
