Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Problem with Media player Classic
    Aug 2007
    hi , i dont if this is a error , or i dont know what happen , the problem is , when i open video option , and play any video from video folder , play perfect ,but when this video is finish and open the browser videos , for select another video , play the same video what i last play , the only way what the new video is close video option , and open again , but when the video is finish , the problem is the same .....
    anyone know , why ? or is normal , before i play perfect , i dont know why now have that problem
    thanks
    Aug 2010
    Bahrain
    Did you try updating the program??
    Aug 2007
    you say the media player classic ? the RR have the version 6.4.9.0 , but i download the last , i think , the 6.4.9.1 and is the same problem
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    Quote Originally Posted by mikeeps2 View Post
    i also use the mediaplayer 6.4.9.1 and never had the problem you have.
    in my install it changed automaticly to the next video if the video is finished.
    did you ever take a look inside the mplayerc configuration file ?
    Aug 2007
    i never look inside of mplayerc configuration ? i need configuration something ? maybe that is my problem , what i need do ?
    i only video option put that on RR.ini
    [Video]
    VideoPlayer=MPCVidRR
    VideoPath=C:\VIDEOS
    RRVideoBrowse=False
    VideoAutoHide=True
    VideoHideTime=4
    VideoFiles=.avi,.mpeg,.mp4,.mpg,.wmv
    VideoShuffle=False
    NoZoom=False
    [Video - Media Player Classic - Home Cinema]
    MPCHCPath=
    [Video - Media Player Classic]
    MPCPath=C:\Program Files\RideRunner\mplayerc.exe
    what other configuration i need do ?
    Aug 2005
    germany
    hi,
    can you please give both files... rr.ini and the mplayerc.ini... for a test on my system ?
    regards
    [Video]
    VideoPath=C:\VIDEOS
    RRVideoBrowse=False
    VideoAutoHide=True
    VideoHideTime=4
    VideoShuffle=False
    NoZoom=False
    MPCHCPath=
    Aug 2007
    sure , but i never change nothing inside mplayerc.ini , i leave same when install RR ,thanks
    Attached Files Attached Files
    Aug 2005
    germany
    hi,
    both inis are not the reason for your prob.
    now i have sometimes the same fault. always if the files are bigger. if they are smaller...under 8 minutes..it changes automaticly to the next file.
    what i will now doing is, a folder with only .avi files, one with only .mpeg files and one with .wma files.
    perhaps its a prob with the player. i also installed the 64 bit version mpc-hc (use win7/64bit) and its the same.
    regards
    Aug 2007
    i use windows xp , i all my videos are MPEG-4 and the more big is 136 mb
    but you see the mplayerc.ini , all is correct , dont need change something ? i leave for default , when install RR
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I don't use the classic but mpc-hc:
    MPCHCPath=C:\Program Files\MPC-HC\mpc-hc.exe
    MPCPath=C:\Program Files\Ride Runner\mplayerc.exe
    You can download it
  1. RR/Media Player Classic hanging when playing video
    By RS200Z in forum RR Bug Tracker
    Last Post: 05-17-2008, 12:04 PM
  2. media classic player...
    By brandensin in forum Road Runner
    Last Post: 02-25-2008, 08:06 PM
  3. Video & Media Player Classic problem
    By RS200Z in forum Road Runner
    Last Post: 07-25-2007, 08:49 PM
  4. RR Media player classic jerky
    By Fritzee in forum RR Bug Tracker
    Last Post: 02-16-2006, 10:12 PM
  5. Windows Media Player Classic - I don't like it!!!
    By tonyrums in forum Road Runner
    Last Post: 02-11-2006, 10:17 PM
