Results 1 to 6 of 6
Thread: Winamp Not starting in RR 11/1/13
    Sep 2008
    Just got done reinstalling the latest version of RR, 11/1/2013, and Winamp, 5.65. They are running on an XP svc pack 3 machine that has been running older versions of both products fine for several years. Now I have to start Winamp manually before RR sees it. All paths look fine in config including the path to Winamp. Any idea where else I should check? Thanks.
    Just reinstalled Winamp 2.95 and still RR does not start the Winamp application.
    Sep 2012
    Germany - Munich
    try it again after switching winamp to classic skinstyle.
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Also make sure "Auto" is selected. This seem to fix the problem for me.
    Good luck.
    Sep 2008
    Thanks, I tried both but no joy. I finally reinstalled to older versions of both Winamp and RR and all works well. I did get the newest versions to work together on a Win7 machine but not on XP. Probably user problems but not going to bother as its working.
    MySQL Error
    Oct 2004
    you really shouldn't mix versions... due to how COM dlls work on windows
    install the newest RR, install the newest Winamp, don't use any of that old non Unicode versions
    set winamp to use classic view
    go to rrconfig, set it up for winamp...
    and it just works... ive never seen it not...
    if you need more information, enable debug, and review the debug.txt
    m
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    MySQL Error
    Oct 2004
    do not try to run an old version of rr and new version of rr on same pc
    while its possible, if you run say the OLD RRCONFIG, it will blow registration of dlls on ya
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Carputer starting, but not starting... frustrating!
    By GarryP in forum General Hardware Discussion
    Last Post: 09-10-2011, 11:22 AM
  2. Newb question - Winamp Starting text
    By Tzunami in forum Road Runner
    Last Post: 08-28-2006, 02:51 PM
  3. RR hangs at "Starting Winamp..."
    By Change in forum Road Runner
    Last Post: 07-21-2006, 10:01 PM
  4. help:winamp hotkeys in Medicar and other winamp based Front ends?(concerning IRinput)
    By powerslide in forum Software & Software Development
    Last Post: 04-05-2005, 05:12 AM
  5. Winamp 5 final version out...Arby skin for winamp 5???
    By bankingdom in forum Software & Software Development
    Last Post: 12-27-2003, 10:10 AM
