Results 1 to 7 of 7
Thread: Carwings lite - not muting winamp when DVD is started ?
    Nov 2013
    I am a newbie working with riderunner and working out how it all goes together. I am getting there and will have several questions about coding and where stuff is located but my first question is about the current buld with Carwings that comes with it. It appears that there is a missing event command to mute Winamp when loading a DVD. What should I add where ?
    jim
    MySQL Error
    Oct 2004
    why would we want to mute winamp?
    what does winamp and "loading a dvd" have any connection?
    if you have your winamp, set to PLAY dvds, disable that!
    rip winamp too
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Nov 2013
    If I am playing music and I load a DVD, the music does not stop when the DVD starts and sound from both comes through the system
    Nov 2013
    Using MPC-HT for video and DVD player
    MySQL Error
    Oct 2004
    it should pause..
    and not because you "load a dvd"
    but because you go to the VIDEO or DVD player
    if you want it to pause when you "load a dvd" some event has to happen
    then on that event, you would switch to "DVD"
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Nov 2013
    OK --- the event for recognizing that a DVD has been put in the drive is already somewhere in the events coding, as when I do that, it automatically switches to the DVD player within RR. I need to look for that event and then also add another similar event to pause winamp ?
    MySQL Error
    Oct 2004
    no...
    sounds like its switching to DVD wrong!
    as if it was correct, winamp would be paused
    carwings as a base doesn't have the event to auto switch...
    maybe its in the global exectbl.ini
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Carwings Dynamic Lite DAYTIME
    By fixerofallthing in forum RR Skins in Progress
    Last Post: 06-14-2010, 01:10 AM
  2. Replies: 8
    Last Post: 11-19-2009, 10:54 AM
  3. psd carwings
    By elektro2000 in forum RR Skins
    Last Post: 07-18-2009, 02:27 AM
  4. Muting Winamp/Wave on external line in
    By rodweb in forum Road Runner
    Last Post: 09-03-2008, 05:54 AM
  5. 1992 Maxima (just started, well ... just started progress)
    By arsalan_altaf in forum Show off your project
    Last Post: 10-18-2002, 03:55 PM
