Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 59
Like Tree2Likes
Thread: RR Android alpha testers
  1. #21
    Aug 2007
    Quote Originally Posted by guino View Post
    Your PM is full so I wasn't able to send you the info.
    hi , sorry , i clear a little space , is ready you send me or i send you a PM with my email
  2. #22
    Oct 2008
    Is there any logging created when running? Riderunner closes immediately upon opening. Looks like it is attempting to download something. Should i be on WIFI for the download?
    I have a HTC Thunderbolt, Rooted, running 4.0.4, and a custom ROM/Kernel/Radios.
  3. #23
    Sep 2012
    Germany - Munich
    would be cool to see some photos.
  4. #24
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    for anyone havig the problem of RR shuting down as soon as it is opened.. Please rename the skins folder "RRSkins" it is CASE SENSITIVE.. so "rrskins" and "RRskins" will not work
  5. #25
    Newbie bhitman's Avatar
    May 2008
    Runkel, Germany
    Thank you for the "test-app".
    The app works at all, but on every start it goes to "verifying download"...
    First impressions:
    1st: the skin did not expand to the tablet desktop (I see it in 4:3 format with huge borders).
    2nd: the fonts of the mp3-tags on the right side are to small.
    3rd: the music list shows all my songs in one list
    But the concept is on the right way!!!
    Intel D945GCLF2, 2GB RAM, 160GB SATA, DVD-ROM SATA, WiFi Belkin USB, Navibe-GPS-Mouse, TFT 7" Lilliput, Win XP SP3, Silabs-radio, bluetooth by bluesoleil, RR last versions
  6. #26
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    got it working on the Nexus 7 2012 with USBRom.
    copied files over to the root directory (there is no /sdcard directory), installed the apk file after enabling software from unknown sources, and it would start and try to download resources without success.
    rebooted and started again, resources downloaded successfully and there is carwings on the screen!!!!!
    music plays, videos play, launch pulls up the list of applications
    XM, NAvigation, Weather do nothing, but long press brings up application list, press cancel and then RR crashes
    first attempt to run again crashes, but next attempt works
    appears to check for resources on each run, perhaps a type of auto updater?
    long press on radio, selected android app tune in radio, dynamic button updated to tune in radio, but opens mp3 player when attempt to run
    long press on navigation, select google maps. dynamic button/label updates, and google maps opens!!! back button takes you back to RR!!!
    excellent potential here
    same screen resolution issue as bhitman wrote about
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
  7. #27
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Suscribed.
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  8. #28
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    The resolution is set in the general.ini of the skin.
    try changing
    ShowWidth=800
    ShowHeight=600
    to whatever the resolution of your tablet is.
  9. #29
    May 2008
    Runkel, Germany
    That was the first, which I tried. But after every (re)start, the general.ini is replaced with the original settings.
    In addition the folder RRSkins is generated automatically in sdcard0 (the internal one) und not on sdcard1 (external).
    The next issue: I can't see any video-files (and I've a lot!)
    Will it be possible in the future to use own skins?
  10. #30
    Variable Bitrate eugenweij's Avatar
    Aug 2010
    Rozenburg, Netherlands
    here is what it looks like on my tab:
    View my worklog here
  1. Replies: 14
    Last Post: 07-28-2012, 01:20 PM
  2. Android skin - alpha coming soon!
    By detlion1643 in forum OpenMobile Skins
    Last Post: 06-14-2012, 06:14 AM
  3. Need some testers Please :)
    By frodobaggins in forum FrodoPlayer
    Last Post: 08-08-2004, 08:10 PM
  4. Need Testers Please for TV app.
    By frodobaggins in forum Software & Software Development
    Last Post: 07-07-2004, 07:03 PM
