Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Label MEM incorrect
    Mar 2011
    Label MEM incorrect
    does anyone know explain to me why the label MEM does not correctly detect the actual use of the PC's memory?
    Mar 2011
    Alright guys since no one answers and this RR is full of bugs step in Centrafuse.
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    In my Vista 32 bits , the label 'MEM' return me '36%'. How do you use it (send your .skin file !!!)
    I hope that Centrifuge give you what you need (freely :-) )
    Mar 2011
    In win7 is win 8 don't function.
    May 2008
    Bordeaux, France
    May be mitchjs can see that ?
    Mar 2011
    I can just public string label of the MEM. I have an actual consumption of 20% rr but says that I am consuming 77%. because it is a misreading?
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    Quote Originally Posted by Carlo201983 View Post
    MEM shows you the Value of FREE Memory in Percent,
    ALLMEM shows you the Value of Memory you have in your PC in MB
    FREEMEM shows you the Value of FREE Memory in MB
    take a look with a running stream also and you see that the value of MEM and FREEMEM will be smaller
    Mar 2011
    Quote Originally Posted by GF-ler View Post
    finally a person who explained everything well. so it all adds up. I'll just do a test in front of the pc. thank you very much
    Aug 2007
    carlo , but that all info you find in RR documentation , skin commands
    "CPU" - Shows CPU Load % (Ride Runner Only)
    "MEM" - Shows Total Memory usage % (Ride Runner Only)
    "FREEMEM" - Shows Physical Memory available (Kb can be used as format, otherwise it is in Mb)
    "ALLMEM" - Shows Total Physical Memory (Kb can be used as format, otherwise it is in Mb)
    "PAGEMEM" - Shows Page Memory available (Kb can be used as format, otherwise it is in Mb)
    "PAGESIZE" - Shows Page Memory Size (Kb can be used as format, otherwise it is in Mb)
    "ALLFREEMEM" - Shows All Memory available (Kb can be used as format, otherwise it is in Mb)
    "TOTALMEM" - Shows Total Memory size (Kb can be used as format, otherwise it is in Mb)
    MySQL Error
    Oct 2004
    when reading documentation to me "MEM" should show used... not free %, but I changed documentation "MEM" is free %
    I added "RRMemoryUsed%" which is used %
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  1. create label from existing label with math opertions...
    By sgtpepperaut in forum Road Runner
    Last Post: 11-18-2009, 01:33 AM
  2. Duration of MP3 Incorrect
    By Mbai2 in forum CF Bug Reports
    Last Post: 12-21-2008, 07:04 AM
  3. POIs incorrect?
    By bash1979 in forum StreetDeck
    Last Post: 05-30-2006, 04:51 PM
  4. Incorrect resolution
    By DK888 in forum LCD/Display
    Last Post: 06-07-2005, 12:24 PM
  5. The parameter is incorrect
    By braindrain in forum PowerVoice
    Last Post: 05-02-2005, 12:41 AM
