Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: battery percentage
    Newbie elli_h's Avatar
    May 2006
    israel
    battery percentage
    Hi all
    Is there a way to display the battery percentage or Charging of the computer on the RR screen ?
    Sep 2012
    Germany - Munich
    found in a vb5/6 forum this code and added a timer, to get the accu state every second.
    with a plugin is it possible. maybe adding to RR too.
    http://www.activevb.de/tipps/vb6tipps/tipp0530.html
    found an other better working code here:
    http://www.vbarchiv.net/tipps/tipp_1...-abfragen.html
    above form with second script:
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Deleted !!!
    Sep 2012
    Germany - Munich
    May 2006
    israel
    Hi pierrotm777
    Thanks for the fast replay & the plugin
    I installed the plugin and the sample skin
    This is what I get
    Sep 2012
    Germany - Munich
    did you the test on virtual machine?
    May 2006
    israel
    no
    Sep 2012
    Germany - Munich
    take a test with the exe.
    May 2006
    israel
    What it means
    Sep 2012
    Germany - Munich
    try this. have deleted the incl. progressbar.
    Attached Files Attached Files
  1. Replies: 3
    Last Post: 01-08-2012, 04:05 PM
  2. Replies: 7
    Last Post: 06-01-2008, 11:36 AM
  3. Dual-battery setup with a smaller battery?
    By kbyrd in forum Power Supplies
    Last Post: 12-10-2005, 01:17 PM
  4. Replies: 3
    Last Post: 08-04-2004, 04:52 AM
  5. Percentage of use
    By tation in forum Off Topic
    Last Post: 04-17-2002, 08:12 AM
