Results 1 to 4 of 4
Thread: Does Riderunner.exe accept any commandline parameters?
    Nov 2006
    Does Riderunner,exe accept any command line parameters?
    I would like to specify the path to either rr.ini or to the skin directory on the command line in a shortcut.
    I run multiple riderunners on a tablet (obviously one at a time) where the difference is primarily the skins used.
    When we are home, the tablet hangs on a wall running RR with a skin set built to control household things like HVAC, lights, security cameras, calendars, and other such stuff.
    However, when we "go on the road", I start a different riderunner with a skin set built to support our RV travels.
    Right now, in order to switch I either edit rr.ini or I use RRConfig to change the skin path which is a bit of a pain.
    I'd rather not dynamically update rr.ini as Windows 8 is quite fussy about programs updating things in Program Files.
    Regards,
    Jim
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Why not use the Day and Night skins as Home and Road?
    Otherwise you can program a button to switch between two different skins.
    or if you use the day and night skins for both home and road then you can program a button to switch both day and night skins to different ones.
    Nov 2006
    Obviously, I hadn't thought of that approach.
    Just to save me a little time, what command changes the skin (Day to Night and vis-a-versa)
    Regards,
    Jim
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    "DAYNIGHTSKIN" - This toggles between your Day and Night Skin and Auto Mode
    "DAYSKIN" - Sets DAY Skin regardless of current skin
    "NIGHTSKIN" - Sets NIGHT Skin regardless of current skin
  1. integreate IMG in more layer by one commandline?
    By harryberlin in forum RR Skins
    Last Post: 12-24-2012, 08:25 AM
  2. rating on winamp with commandline
    By Diavoletto in forum Road Runner
    Last Post: 09-20-2012, 05:39 AM
  3. Parameters
    By fronzt in forum Centrafuse
    Last Post: 04-28-2008, 03:53 AM
  4. change ecm parameters
    By turbochris in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-13-2007, 06:02 AM
  5. Enhanced Parameters?
    By dabigguy in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-28-2006, 05:52 PM
