Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: RR 01/01/2014 Release
  1. #11
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I have a little issue with the directory list (SD):
    I use these lines :
    [List]
    SD,00,00,-1,-1,"$RRGMAILPATHFILE$","*.*",True
    S,35,57,534,163,255,255,255,255,255,255,064,064,06 4,255,128,000,TRUE,18,"Arial:B"
    IL,DL,TRANSPARENT.BMP,SEL.BMP,END.BMP,0,50,60
    My problem is if i change the variable path value into my settings , i need to do a reloadscreen or reloadskin if i want to see the good value into the screen where are these lines !
    1-Does exist another method ?
    2-Is it possible to have the possibility to use label as path into the SD line (because always updated)?
    Sep 2012
    Germany - Munich
    i think this topic should be an own thread.
    what happens when you use the cmd SETPATH?
  3. #13
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by pierrotm777 View Post
    I use these lines :
    [List]
    My plugins have their own file browser coded in them (when they are needed) and I just use a custom list.
  4. #14
    May 2008
    Bordeaux, France
    Quote Originally Posted by Enforcer View Post
    Thanks Enforcer for your help ! In fact it's an idea , but i should like use the SD list method if possible !
  1. Garmin Mobile PC 2014 Maps install - Success
    By Dluvr22 in forum Garmin Mobile PC
    Last Post: 08-03-2015, 06:50 PM
  2. Can-am 2014
    By SNOtwistR in forum MP3Car Gatherings
    Last Post: 07-24-2014, 10:40 AM
  3. Replies: 21
    Last Post: 04-01-2011, 09:59 AM
  4. Need some help on 2014 and 4034
    By peter3 in forum LCD/Display
    Last Post: 08-10-2001, 09:22 AM
  5. LCD 2014 ?s
    By Frickn in forum General Hardware Discussion
    Last Post: 09-09-2000, 08:46 PM
