Results 1 to 10 of 12
Thread: Serial read/write? Aka interfacing with an arduino
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    I am trying to decide on if I want to go with a car pc on my next build and decided it'll primarily hinge on arduino integration. Does RR have the ability to communicate with and arduino via the serial signal on the com port?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Dec 2004
    Los Angeles Ca
    45 views and no input. I have been thinking about this for a while now and after reading the faq http://www.mp3car.com/rr-faq/86680-h...n-with-rr.html I think i have a very simple 'hack' that will get some basic functionality and a sudo 'serial' interface of sorts. the Arduino can simulate keyboard presses, so instead of serial, it can communicate that way. I assume it doesn't really help if you need a realtime analog input but it's a hack for now. but that doesn't solve the output issue... only input
    another option is to embed an processing2.js app
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    You should have a look at phidgets. There are plugins or built in support for CF, RR and Driveline will do all you want and analog too. Just a suggestion SNO
    Dec 2004
    Los Angeles Ca
    I'm in a bit deep with arduino right now and there is a level of versatility i can achieve with arduino that i can't with phidgets... with out knowing c++
    thanks for the suggestion though
    M10k
    My Car Pc Install
    My Boat Pc worklog
    May 2012
    Grandville, MI
    If you really desire that you could always look at the code for the phidgets plugin and built your own plugin...
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by redheadedrod View Post
    hmm..not sure if this is out of my capacity but it's worth looking into! thanks for the suggestion
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Nov 2013
    What arduino are you using for keyboard emulation?
    Also what information are you trying to communicate between the arduino and RR?
    Dec 2004
    Los Angeles Ca
    you can use a mega adk for the keyboard emulation.
    things i want to control:
    outputs:
    seat heaters
    power locks,
    power windows
    possibly distance sensor
    inputs:
    rotary encoder
    capacitance buttons
    i have a shield that will take voice commands which i'd like to map them to certain functions.
    i'd probably set it up so you dont need to have the pc running to use most of the features (door locks, windows etc...)
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by scott_fx View Post
    An plugin that communicate with arduino exist !
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by pierrotm777 View Post
    i've searched the plugin dir for arduino and haven't found anything. What is the name of the plugin?
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. arduino to read car sensors
    By settra in forum Hardware Development
    Last Post: 11-01-2013, 07:03 PM
  2. VB6 module to read and write ID3 tags (attached)
    By ClockWorK in forum Software & Software Development
    Last Post: 01-03-2010, 11:28 PM
  3. Read / Write Can bus
    By BCasey in forum General MP3Car Discussion
    Last Post: 09-05-2008, 09:31 AM
  4. software to read/write to 8 DS1621s
    By greenman100 in forum Software & Software Development
    Last Post: 05-09-2005, 07:05 AM
  5. Can the CW-8123 read/write mini CDs?
    By rando in forum General Hardware Discussion
    Last Post: 01-15-2005, 06:18 PM
