Results 1 to 10 of 12
Thread: Label Options Bug
    Sep 2012
    Germany - Munich
    Label Options Bug
    I have a small bug with Labels.
    If i set from LEFT to SCROLL and scale my skin with general.ini bigger than real size. the label height don't scale.
    LEFT = all is fine
    SCROLL = height of Label don't scale. the text gets a cut on the bottom.
    MySQL Error
    Oct 2004
    make a demo
    just a label on menu.skin will do
    (have all the files required for demo)
    zip and attach
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Sep 2012
    Germany - Munich
    see attached files
    Attached Files Attached Files
    MySQL Error
    Oct 2004
    I think its working correctly
    you're using a really really big font, I think the font scale is the issue
    and prob how windows scales fonts!
    try it at same size
    OriginalWidth=1066
    OriginalHeight=600
    ShowWidth=1066
    ShowHeight=600
    and you will see that it doesn't fit
    oddly a specified height of 50, results in a 75px need to draw the Arial font
    and the usual label while you set the height to 50, is actually turning into 75
    this is all related to a font sizing issue and its a known issue apparently
    so change to
    L,020,100,450,075,0,0,0,50,"Arial","=SCROLL-LABEL","SCROLL",,""
    note 75 tall
    and if you want that drop shadow the label needs more space use 80 then
    *for basic labels, rr does this resize for you... I let you know more when I understand why rr
    is specifically not automatically fitting the font, more I think about it, it prob shouldn't anyway
    if you specify a font too big for label, that's your fault
    but as you can see textheight doesn't equal label size, so you cant just drop in numbers
    prob related to font kerning
    can rr be made to auto fit the font for scrolls, yet...
    but before I do, I need to see why its explicitly told not to
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    oh if you don't believe me try
    L,550,100,450,10,0,0,0,50,"Arial","=USUAL-LABEL","LEFT",,"DS=2,2,80,80,80"
    note size of 10... it will resize to at least 75!
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Sep 2012
    Germany - Munich
    both labels have the same size and font-size.
    but in illustration exist differences.
    the fontsize 50 is just an example. the issue exist with 16 too.
    my complete skin is created in 1066x600. But i want use it with 1366x768, because some windows like window screen settings does not fit in screen by heigt 600. can't see the ok or cancel button.
    Sep 2012
    Germany - Munich
    ok, if i understand.
    i should resize the label-heigt bigger as the font, and all is fine.
    MySQL Error
    Oct 2004
    I meant to take out that big font stuff, size of font not matter
    a font of say 20, doesn't fit into a label sized 20
    you need the label bigger!
    also consider drop shadow adds to size a few px
    so.. make label area bigger so font will fit
    then all is good
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Sep 2012
    Germany - Munich
    ok. now i understand.
    but why is this difference between these two labels?
    sorry, for my bad english.
    MySQL Error
    Oct 2004
    there isn't, except... non scroll rr will resize it
    try my example
    this says 10, but clearly the whole font is there.. so how did it fit 50(which turns out to be 75) to fit?
    rr resizes improperly done labels
    I don't have an answer that makes sense, but what you have to do on ALL labels, is make it look right
    if its right, it will scale...
    in this case
    L,550,100,450,80,0,0,0,50,"Arial","=USUAL-LABEL","LEFT",,"DS=2,2,80,80,80"
    80 since I got drop shadow too
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. create label from existing label with math opertions...
    By sgtpepperaut in forum Road Runner
    Last Post: 11-18-2009, 01:33 AM
  2. how to change rr label from sdk?
    By spidermunz in forum Road Runner
    Last Post: 06-11-2008, 08:53 AM
  3. multiline Label tag ??
    By jamedinar in forum Road Runner
    Last Post: 04-17-2008, 11:46 PM
  4. Mouse options: touchpad versus other options
    By Brycestro in forum Newbie
    Last Post: 01-15-2007, 01:35 PM
  5. Help with RR label
    By WarningSLO in forum RR Skins
    Last Post: 11-15-2006, 06:03 PM
