Results 1 to 10 of 15
Like Tree1Likes
Thread: BYVARX issue
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    BYVARX issue
    In my last RRGmail version, i can send a mail with or not attached file by a simple line command:
    rr_gmail_sendemail;toaddress;subject;body;file
    RR_GMAIL_SENDEMAIL;[email protected];urgent;gm ail have email;C:\Temp\GMAIL\test1.txt
    I friend ask me to use this command with the BYVARX command and that don't run !!
    BYVARX;SENDER_ALERT;(DONOTHING<<RR_GMAIL_SENDEMAIL ;[email protected];urgent;gmail have email;C:\Temp\GMAIL\test1.txt)
    I have found a solution!
    I add this line into my exectbl.ini file:
    "SENDOK","RR_GMAIL_SENDEMAIL;[email protected] ;urgent;gmail have email;C:\Temp\GMAIL\test1.txt"
    And i replace my BYVARX command by a simple BYVAR command
    BYVAR;SENDER_ALERT;DONOTHING<<SENDOK
    An idea why the BYVARX command don't run ?
    Sep 2012
    Germany - Munich
    i don't use your plugin, but i tried the command.
    i think it should work
    Code:
    18:45:22,594: Que Exec: True, menu.skin, "BYVARX;SENDER_ALERT;(DONOTHING<<RR_GMAIL_SENDEMAIL ;[email protected];urgent;gmail have email;C:\Temp\GMAIL\test1.txt)", False
    18:45:22,602: Executing: BYVARX;SENDER_ALERT;(DONOTHING<<RR_GMAIL_SENDEMAIL ;[email protected];urgent;gmail have email;C:\Temp\GMAIL\test1.txt)
    18:45:22,602: Que Exec: True, menu.skin, "DONOTHING", False
    18:45:22,609: Executing: DONOTHING
    18:45:22,609: Command not executed: DONOTHING
    18:45:22,609: Que Exec: True, menu.skin, "ONCOMMANDINVALID", False
    18:45:22,609: Executing: ONCOMMANDINVALID
    18:45:22,609: Leave Exec: False, menu.skin, ONCOMMANDINVALID, False
    18:45:59,141: Enter Exec: False, menu.skin, , False
    18:45:59,141: Que Exec: True, menu.skin, "SETVAR;SENDER_ALERT;01", False
    18:45:59,148: Executing: SETVAR;SENDER_ALERT;01
    18:45:59,148: Leave Exec: False, menu.skin, SETVAR;SENDER_ALERT;01, False
    18:46:00,734: Enter Exec: False, menu.skin, , False
    18:46:00,734: Que Exec: True, menu.skin, "BYVARX;SENDER_ALERT;(DONOTHING<<RR_GMAIL_SENDEMAIL ;[email protected];urgent;gmail have email;C:\Temp\GMAIL\test1.txt)", False
    18:46:00,742: Executing: BYVARX;SENDER_ALERT;(DONOTHING<<RR_GMAIL_SENDEMAIL ;[email protected];urgent;gmail have email;C:\Temp\GMAIL\test1.txt)
    18:46:00,742: Que Exec: True, menu.skin, "RR_GMAIL_SENDEMAIL ;[email protected];urgent;gmail have email;C:\Temp\GMAIL\test1.txt", False
    18:46:00,750: Executing: RR_GMAIL_SENDEMAIL ;[email protected];urgent;gmail have email;C:\Temp\GMAIL\test1.txt
    18:46:00,750: Command not executed: RR_GMAIL_SENDEMAIL ;[email protected];urgent;gmail have email;C:\Temp\GMAIL\test1.txt
    May 2008
    Bordeaux, France
    Try my plugin with this screen and you will see that the BYVARX don't run with the line that follow:
    B,87,208,240,71,"BYVARX;SENDER_ALERT;(DONOTHING<<R R_GMAIL_SENDEMAIL;[email protected];urgent;gma il have email;C:\GMAIL\Lighting.jpg)",""
    But the BYVARX that define the SENDER_ALERT var run very well !!!
    B,485,125,76,71,"BYVARx;SENDER_ALERT;(SETVAR;SENDE R_ALERT;1||SAVETOSKIN;SENDER_ALERT;1<<SETVAR;SENDE R_ALERT;0||SAVETOSKIN;SENDER_ALERT;0)",
    Idem for the command that read the exectbl.ini file:
    B,86,115,240,71,"BYVARX;SENDER_ALERT;(DONOTHING<<S ENDOK)",
    with into my exectbl.ini file:
    "SENDOK","RR_GMAIL_SENDEMAIL;[email protected] ;urgent;gmail have email;C:\GMAIL\Lighting.jpg"
    Attached Files Attached Files
    Sep 2012
    Germany - Munich
    Did you tested with 00 and 01 as var?
    What says the debug log?
    Can i get the plugin files seperatly. i don't like the installer.
    May 2008
    Bordeaux, France
    Quote Originally Posted by harryberlin View Post
    http://www.mp3car.com/vbulletin/atta...-bin-files.zip
    May 2008
    Bordeaux, France
    With 01, the command that follow don't run:
    and the command that read the exectbl.ini file run:
    Sep 2012
    Germany - Munich
    How looks your Function ProcessCommand in RRExtension?
    May 2008
    Bordeaux, France
    It's not into the plugin but used into the skintool for test or into a button !
    Sep 2012
    Germany - Munich
    Don't understand what you mean.
    mikeeps said there is a problem by riderunner because the many ";".
    a little bit confuse.
    it works by disabled plugin.
    thats why the question about your RRExtension.vb.
    May 2008
    Bordeaux, France
    Ho, this is my code!
    Code:
            'rr_gmail_sendemail;toaddress;subject;body;file
            If LCase(CMD).Contains("rr_gmail_sendemail;") Then
                AttchedFile = ""
                Username = FuncCls.DecryptPassword(INI.ReadString("Gmail", "Username", ""))
                Password = FuncCls.DecryptPassword(INI.ReadString("Gmail", "Password", ""))
                sArray = LCase(CMD).Split(";")
                If sArray.Length = 4 Then
                    If gmail_send(sArray(1), sArray(2), sArray(3), "", SDK.GetUserVar("RR_GMAIL_USRLOGO")) = True Then
                        RaiseEvent GmailSendEmail()
                        If MessageOnOff = True Then SDK.Execute("SETVAR;RR_GMAIL_IDLE;3||SETVARFROMVAR;RR_GMAIL_INFO;l_set_SendRRGmail||MENU;RRGMAIL_NEWMAIL.SKIN||WAIT;3||SETVAR;RR_GMAIL_INFO;")
                    End If
                ElseIf sArray.Length = 5 Then
                    If gmail_send(sArray(1), sArray(2), sArray(3), sArray(4), SDK.GetUserVar("RR_GMAIL_USRLOGO")) = True Then
                        If MessageOnOff = True Then SDK.Execute("SETVAR;RR_GMAIL_IDLE;3||SETVARFROMVAR;RR_GMAIL_INFO;l_set_SendRRGmail2||MENU;RRGMAIL_NEWMAIL.SKIN||WAIT;3||SETVAR;RR_GMAIL_INFO;")
                    Else
                        SDK.ErrScrn("Error found !!!", SDK.GetUserVar("l_set_NoSendRRGmail") & " '" & sArray(4) & "' !!!", "************************************************", 5)
                    End If
                End If
                ProcessCommand = 2
            End If
  1. BYVARX question
    By obrienj in forum Road Runner
    Last Post: 04-25-2011, 05:37 PM
  2. GPS issue
    By diggla in forum GPS
    Last Post: 10-12-2009, 03:42 PM
  3. NAV issue?
    By ekaz in forum Centrafuse
    Last Post: 05-16-2008, 04:23 PM
  4. .M3U issue "Play all" issue
    By Kimota in forum StreetDeck
    Last Post: 12-12-2007, 10:34 AM
  5. 2.3.4 and XM issue
    By tmar89 in forum Media Engine
    Last Post: 03-24-2006, 09:54 AM
