Results 1 to 8 of 8
Thread: about visu transparency
    Aug 2007
    Hello, I'm using WMP, but I would like to have on my skin, some slider to change the transparency of visu
    as I can do that?
    Sep 2012
    Germany - Munich
    an other simple method(workaround) could be:
    if you add buttons to calculate the var OpacityVisu in 1 or 10 steps
    but i don't know what happen, if you go out the range 0-100.
    ButtonCommandCode
    Code:
    eval;OpacityVisu;$OpacityVisu$+1
    eval;OpacityVisu;$OpacityVisu$+10
    eval;OpacityVisu;$OpacityVisu$-1
    eval;OpacityVisu;$OpacityVisu$-10
    Sep 2012
    Germany - Munich
    i found time to write a little "helper" for you.
    Attached Files Attached Files
    Aug 2007
    hi , thanks harry ,I drop it and add the folder in the plugins folder, right? register it and add a slider with that command
    "SLDOpacityVisu"
    but does nothing? or should add?
    Sep 2012
    Germany - Munich
    The slider has the same name like the var = opacityvisu
    Aug 2007
    perfect , thanks so much , work perfect
    Sep 2012
    Germany - Munich
    added the cmd to save the var to ini.
    Aug 2007
    hi , i check in skintool and see this
    SldrSet: opacityvisu : 40671
    SAVETOINI;OPACITYVISU;62
    ONSLDopacityvisu
    but into skin.ini but dont see nothing
    oh , i check again , into rr.ini , i see there
    [Audio Player - Visuals]
    VisuName=WMPVis
    TransparentVisu=True
    OPACITYVISU=22
    I thought it was in skin.ini
    By fruchtfliege in forum Road Runner
    Last Post: 10-09-2011, 11:57 PM
  2. CFX TX (Transparency Revolution)
    By MatrixPC in forum RR Skins No Longer Supported
    Last Post: 08-27-2009, 08:24 AM
  3. Transparency help...
    By marazi in forum RR Skins
    Last Post: 09-21-2006, 01:49 PM
  4. Transparency
    By r600rkt in forum Road Runner
    Last Post: 08-29-2006, 03:10 PM
  5. Gif Transparency Support?
    By PCF_Ronin in forum ME Archive
    Last Post: 12-20-2003, 06:32 AM
