Results 1 to 10 of 19
Thread: Trouble with rrpl.m3u8 (RR removes non ASCII characters) - Not RR but Winamp
    Sep 2012
    Germany - Munich
    Hi
    I have trouble by resuming the playlist.
    I think the problem is, RideRunner saves the playlist not in UTF-8. But m3u8 should have utf-8. The normal m3u is ansi.
    After reloading RideRunner there are missing letters like "" and so on. So i can't play these tracks.
    edit:
    very confuse. after deleting again the rrpl.m3u8 i get always an utf-8 file.
    after lot of tests: winamp is the tool, who writes the pl sometimes in wrong format.
    Sep 2012
    Germany - Munich
    OK, now i did lot of tests and i think the problem comes from RideRunner.
    Did the same Tests with Winamp (standalone) without error.
    After Closing RR it writes a new rrpl.m3u8 in cache path. and adds some other information above the track.
    there must be a problem. because sometimes few letters were deleted. so the trackpath is corrupt.
    how is the process in RideRunner?
    MySQL Error
    Oct 2004
    hehe...
    there are no known Unicode issues in RR
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Sep 2012
    Germany - Munich
    OK, but how can you explain this phenomen?
    The Letter "" is missing.
    before:
    after:
    MySQL Error
    Oct 2004
    #EXTINF is generated by Winamp
    and I don't see any difference
    is that notepad? use a better text editor... I use Notepad++
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    I don't have winamp installed, I only got foo
    in the foo case, RR manages the playlist
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Sep 2012
    Germany - Munich
    the difference is the missing letter behind "Gest"
    I opened and closed the rr.m3u8 file with winamp (standalone) more times. winamp never wrote some information in the rr.m3u8.
    Only by using RideRunner the file get the information and the non ascii letters will be deleted.
    Why does save RR on every close the new rr.m3u8 file?
    How is the process?
    BTW: it is equal which editor i use, RR get the same string of corrupt filepath, on loading.
    MySQL Error
    Oct 2004
    ok, I see the missing glyph
    what version of winamp?
    trust me RR asks winamp to write the PL...
    when rr closes, winamp is asked to save the fle
    try foobar....
    remember, if foo not installed, install foo, then reinstall RR, so that it installs the RR plugin
    I don't know what you mean by "BTW: it is equal which editor i use, RR get the same string of corrupt filepath, on loading."
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Sep 2012
    Germany - Munich
    winamp version 5.666 build 3516
    after few tests with foobar, it's ok.
    but foorbar is bad for me.
    my skin is for winamp and foobar needs more than 5 seconds to start playing after RR start.
    foobar has no avs visuals.
    ok, to understand: when RR is closing it saves the values to rr.m3u8 and than winamp ask again to save.
    can you skip this?
    for BTW: the missing strings are not depended on file editors (like notepad or some other). was only an info for you
    MySQL Error
    Oct 2004
    im not sure what is going on for you
    rr asks winamp to save it once...
    maybe there is some plugin in winamp that's cause the issue
    or some setting you got
    foobar can use the AVS visuals, with a plugin
    also of note, for rr, its best not to use any skin for winamp
    just use classic
    but 1st look at all plugins... in winamp
    rr asks winamp to save pl, then copies winamp.m3u8 to rrpl.m3u8
    m
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. New car product: saves miles?
    By skcar303 in forum MP3Car Products - store.mp3car.com
    Last Post: 03-03-2011, 04:44 PM
  2. RideRunner slow to load rrpl.m3u8 with Winamp?
    By MP3DUB in forum Road Runner
    Last Post: 02-11-2011, 09:15 AM
  3. In Car Computing saves the day....again!
    By RedGTiVR6 in forum General MP3Car Discussion
    Last Post: 04-28-2006, 08:14 AM
  4. Software that saves windows sound settings?
    By MoFo in forum Software & Software Development
    Last Post: 03-30-2006, 04:06 PM
  5. Winamp plugin that saves current song?
    By Phacade GSX in forum Software & Software Development
    Last Post: 05-07-2000, 01:04 AM
