Results 1 to 3 of 3
Thread: OSKTEXT issue
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    OSKTEXT issue
    I try to read a var from the skin.ini file to the OSKTEXT var !
    Into my skin.ini file:
    Timer1CMDOn=x10sendplc;on;e1||x10sendplc;dim;e1;50
    But the line that follow return me only 'x10sendplc'
    SDK.Execute("OSKTOCMD;CMDOn;x10_timer_editcmd1onwr ite||OSKTEXT;" & Timer1CMDOn)
    If i replace the ; by , and || by ++ then i can read all my line into the OSK editor and change the line !
    SDK.Execute("OSKTOCMD;CMDOn;x10_timer_editcmd1onwr ite||OSKTEXT;" & Timer1CMDOn.Replace(";", ",").Replace("||", "++"))
    Does exist a solution without change method ?
    Sep 2012
    Germany - Munich
    why do you want use the string in osk?
    you can set the values to seperate vars
    and read the var to execute with your plugin
    May 2008
    Bordeaux, France
    I want the possibility to edit my X10 command .
    An other solution would to create a specific OSK screen , but i don't want that !
    The problem is OSKTEXT;$MYVAR$ don't accept specific characters into $MYVAR$ as ';' or '||' .
  1. M2-ATX issue
    By eribs4e in forum M2-ATX
    Last Post: 08-05-2009, 08:28 AM
  2. OSKTEXT will not show ";" in OSK text box field
    By Sal R. in forum RR Bug Tracker
    Last Post: 04-06-2009, 10:06 PM
  3. .M3U issue "Play all" issue
    By Kimota in forum StreetDeck
    Last Post: 12-12-2007, 10:34 AM
  4. 2.3.4 and XM issue
    By tmar89 in forum Media Engine
    Last Post: 03-24-2006, 09:54 AM
  5. Anyone else have this issue with the BU-353
    By Sonicxtacy02 in forum GPS
    Last Post: 03-09-2006, 05:58 PM
