Results 1 to 5 of 5
Thread: Is there a way to sign RR for Win 7?
    Sep 2012
    Germany - Munich
    Hi Folks
    Do you know a method to sign the RR Appilication and don't get the Notification of Windows Vista or higher?
    I want change the Startup Setting to start directly to RideRunner.
    It is only working with signed Applications.
    Feb 2014
    Same problem on windows 8.1 so would be VERY happy to hear the solution.
    Alternately how to auto run UNsigned applications in win8.
    TIA
    Sep 2012
    Germany - Munich
    a workaround is to use scheduled tasks and add this command in userdefined gui.
    but it's a bad solution.
    Sep 2012
    Germany - Munich
    Sorry, but
    -UAC turning off is bad
    -Startup Folder means, you boot up to explorer
    Sorry, forget this. After some test, there is missing the filemanagment.
    Maybe i should switch back to XP.
    my workaround is this (i only have german windows):
    - add a new Task to run RideRunner with highest privilegs (in my case the task is called "RR")
    - to run the Task use this command "schtasks /RUN /TN RR"
    - then it is just needed to switch from "explorer.exe" to "schtasks /RUN /TN RR"
    - now windows starts directly to RideRunner
    If you want sometimes boot up to Windows Desktop, you can use "RUN;C:\Windows\Explorer.exe"
  1. Can't sign up
    By stric in forum Centrafuse
    Last Post: 03-18-2006, 04:39 PM
  2. OG Members Sign In!
    By SuperAJ in forum Off Topic
    Last Post: 11-01-2005, 06:59 AM
  3. sign uppppppp
    By Vinyl in forum Show off your project
    Last Post: 10-24-2005, 07:23 PM
  4. hmm, i gotta sign up for this one day...
    By nottastocker in forum Off Topic
    Last Post: 02-12-2005, 05:19 PM
  5. OG crew sign in ;-] v.2
    Last Post: 08-29-2004, 02:09 PM
