Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 44
Thread: CDA files with foobar problem in RR
  1. #11
    Mar 2011
    ok thanks anyway. then if there is no way to solve this problem, it will be the right time to spend with each other.
    thanks again, but RR has still several things that do not work.
    will be a beta for a lifetime
  2. #12
    MySQL Error
    Oct 2004
    its not beta... and CDA isn't a "file" type that RR claims to support
    no one single program does everything, like Tidder suggested, try another media player...
    I still have no idea how you get a cda file in the 1st place, without putting in a redbook audio cd
    which is something I don't even have...well I do, they just put away in attic after I ripped them to all mp3 and put on hard drive
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #13
    Mar 2011
    Quote Originally Posted by mitchjs View Post
    Audio players that sound good as foobar does not exist many. Wmp sounds terrible. in addition to not being able to select the ASIO driver of my sound card. cm then WMP does not even display the artist name and song title, it displays "Track. cda" RR unfortunately still has a lot of things that do not work for myself that this seems to be a beta for a lifetime. I personally have clearly u mp3 songs on my hard drive but it is unthinkable that if I have an original CD I can not listen to it because RR did not support.
  4. #14
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Quote Originally Posted by Carlo201983 View Post
    Sounds like you should give Centrafuse a try if your not getting your money's worth out of RR...
  5. #15
    Mar 2011
    Quote Originally Posted by PhilG View Post
    Centrafuse is not even good .. does not choose the audio player that you want to use, so in my case I discarded a priori from the outset.
  6. #16
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    ASIO is pretty important, I agree. Sounds like you should upgrade and get away from Windows XP. The audio engine in Windows 7 sounds much MUCH better than XPs. I don't think you'd even need ASIO if you upgraded.
    It's not unthinkable to have troubles playing a CD. The whole reason most of us are here is to get away from that. Just because Foobar's API doesn't expose a good way to implement CD track playback doesn't mean RR is broken. Perhaps you should email one of the Foobar developers and ask them to fix it.
    This is like saying that because diesel doesn't work in your car, your car must still be in beta. With the right engine you can run diesel.
    Tidder
    Try RevFE
  7. #17
    Mar 2011
    Quote Originally Posted by Tidder View Post
    so what should I ask him if Foobar without RR quietly reads the CDA?
    that RR is in beta for me because apart from this there are other things never reported prior resolved .. the plugin to integrate foobar in RR by whom it was done?
    I think the problem is in there.
  8. #18
    MySQL Error
    Oct 2004
    i wrote the code to interface RR to foo...
    (at this point, I have no immediate plans to look how cda is handled, I do know people play CDs all the time with RR (prob using winamp))
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #19
    Mar 2011
    Mitcjs I'm not in a hurry to get the solution immediately, but I would like to know if you're going to try to fix this problem or not.
    Winamp has become too heavy to run on a PC. chose foobar own for lightness. then read the file with winamp secure CDA. but the titles reads them?
  10. #20
    MySQL Error
    Oct 2004
    I don't think I can fix anything
    foobar uses a plugin foo_cdda to play cd's
    so its handled there
    all i do is use the API's playlist manager, and feed it files...
    if it doesn't work... then it doesn't work
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Visualisation for foobar
    By anuchit in forum RR Plugins
    Last Post: 06-09-2011, 12:40 AM
  2. DRM protected files problem !
    By Jingle in forum Software & Software Development
    Last Post: 11-06-2006, 11:09 AM
  3. Foobar?
    By greenman100 in forum PowerVoice
    Last Post: 12-19-2005, 08:41 PM
  4. Problem playing files
    By RuwKus130 in forum FrodoPlayer
    Last Post: 05-31-2004, 01:33 PM
  5. Replies: 3
    Last Post: 08-14-2003, 09:18 AM
