Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
Thread: CDA files with foobar problem in RR
  1. #21
    Mar 2011
    Quote Originally Posted by mitchjs View Post
    I don't think I can fix anything
    foobar uses a plugin foo_cdda to play cd's
    so its handled there
    all i do is use the API's playlist manager, and feed it files...
    if it doesn't work... then it doesn't work
    I just tried it with winamp and it does not read as I expected it title artist. so at that point do not even need him.
  2. #22
    MySQL Error
    Oct 2004
    how are you getting cda files anyway, are you in the end trying to just play an audio cd?
    ive seen people play audio cds no problem in rr
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #23
    MySQL Error
    Oct 2004
    btw, foobar handles the .cda file when in a playlist, so...
    add a .cda file... exit rr, start rr
    it will play
    so.. this is a foobar problem, feel free to post in their forum, that a .cda by itself wont open right via API (playlist_manager->activeplaylist_add_items)
    it seems to load it as a media file, and not process it as a .cda
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  4. #24
    MySQL Error
    Oct 2004
    ok, I found another API to use
    I have to specifically check that the file ends with .cda
    if it does I do NOT pass it into foobars metadb service
    which if it was a m3u it would then build me a list
    but I send it right to the Playlist Filter process_location() API
    to get a list
    which then is added to the PlayList Manager
    seems to work
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  5. #25
    MySQL Error
    Oct 2004
    foobar does process the .cda (its slow) I think its because of access to cdr
    once its spinning its fast, but I do see the processing file dialog
    (and there seems no option to keep it hidden, with this API)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #26
    MySQL Error
    Oct 2004
    try this file
    it goes
    C:\Users\mitchjs\AppData\Roaming\foobar2000\user-components\foo_rrcontrolserver
    course in your name...
    Attached Files Attached Files
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #27
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    to get a list
    seems to work
    Nice find!
    You may have a hard shell... but you have a sweet, creamy center.
    Tidder
    Try RevFE
  8. #28
    MySQL Error
    Oct 2004
    course, there is no meta data in a .cda file, and therefore you wont get any artist/title information
    which says to me, even more reason to just rip the cd, besides cds are obsolete
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #29
    Mar 2011
    I just replaced the DLL now works but as you mentioned earlier reading files is very slow .. and everyway the names of the artist and song you do not read anyway. if you can not do leave it alone. if you are the only one on the face of the earth to occasionally use the CD. I do not want you to miss any more time. when I will listen to the CD. I open foobar.
    thank you also for what you do
  10. #30
    Mar 2011
    but why foobar can read the data ARTIST AND TITLE?
    I agree with you that the CD is obsolete now, but who uses only audiophile CD AUDIO
  1. Visualisation for foobar
    By anuchit in forum RR Plugins
    Last Post: 06-09-2011, 12:40 AM
  2. DRM protected files problem !
    By Jingle in forum Software & Software Development
    Last Post: 11-06-2006, 11:09 AM
  3. Foobar?
    By greenman100 in forum PowerVoice
    Last Post: 12-19-2005, 08:41 PM
  4. Problem playing files
    By RuwKus130 in forum FrodoPlayer
    Last Post: 05-31-2004, 01:33 PM
  5. Replies: 3
    Last Post: 08-14-2003, 09:18 AM
