Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 44
Thread: CDA files with foobar problem in RR
  1. #31
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by Carlo201983 View Post
    but why foobar can read the data ARTIST AND TITLE?
    I agree with you that the CD is obsolete now, but who uses only audiophile CD AUDIO
    Probably because Foobar also reads CD-TEXT which not all programs can do. I'm not sure how much RR does vs Foobar but I imagine it's because RR doesn't do CD-TEXT.
    This is why FLAC is great. Lossless audio, sounds better than the CD. I'm a huge stickler for audio quality. I can hear the compression in 320k MP3s, drives me nuts. FLAC is the only way to fly.
    Tidder
    Try RevFE
  2. #32
    Mar 2011
    Quote Originally Posted by Tidder View Post
    tider, maybe I can not explain .. I know what a format. FLAC,. APE, etc. etc..
    I repeat again those audiophile cd orginal only listens.
  3. #33
    Sep 2003
    New Mexico, USA
    Yeah I don't think I'm grasping what you're saying. FLAC is a bit for bit perfect representation of the audio data on a CD (as long as no uncorrectable read errors occur), there is zero quality difference. In many cases the quality is better if the optical drive isn't using digital audio extraction; playing like a normal CD player. Even then, some audio quality could be lost when the optical drive skips over areas of the CD that it can't read correctly.
    Foobar plays back FLAC just fine. You can even tag your FLAC just like MP3s, with all the artist and track info you want. If you're an audiophile, why are you using CDs? I'm not poking fun, I'm really curious as to why you think the original CD is better than FLAC.
    Tidder
    Try RevFE
  4. #34
    MySQL Error
    Oct 2004
    i don't think foobar is reading the CD_TEXT, its prob using the FREE CD database, when it sees a whole cd, it sends some data to the database
    and gets a hit...
    I could be wrong, but when I open a SINGLE cda file right in foobar, I don't get any track/artist info
    anyway... this endeavor is ended
    rip the dam cD!
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  5. #35
    Mar 2011
    Quote Originally Posted by mitchjs View Post
    and gets a hit...
    rip the dam cD!
    no no .. but as you can see from the screen .. just foobar reads the CD-TEXT
    Name:  Immagine foobar.png
    therefore in conclusion, RR from this point of view is limited.
    Here's an example:
    And 'unthinkable that a friend of mine come in the car with a CD to listen to it. and I should rip to make him listen. ahahhah
  6. #36
    MySQL Error
    Oct 2004
    well... the cd I used, either doesn't have CD-TEXT or my CDROM doesn't support it
    in any case, RR has its own tag reading...since RR for one there is NO METADATA in a .cda file
    RR has nothing to get!
    RR doesn't officially support .cda anyway... remember rr doesn't itself play ANYMEDIA (technically, it depends on 3rd party)
    if I could parse cd-txt from the .cda I would consider it, but you cant
    just deal with your friends CD with "track01"...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #37
    MySQL Error
    Oct 2004
    and I still not sure it read the CD-TEXT, based on the filename CDDA:// and that hex number
    that's enough information to send to the freecddb
    you disconnected from network at the time?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #38
    Sep 2003
    New Mexico, USA
    Haha! Tell your friend to get with the times and bring a thumb drive with MP3s or FLACs on it next time!
    Tidder
    Try RevFE
  9. #39
    Mar 2011
    mitcjs I confirm that my CD burner writes and reads CD-Text. and that even without internet connection metadata read them equally
  10. #40
    Mar 2011
    Thank you for not having replied to the pm I sent you.
  1. Visualisation for foobar
    By anuchit in forum RR Plugins
    Last Post: 06-09-2011, 12:40 AM
  2. DRM protected files problem !
    By Jingle in forum Software & Software Development
    Last Post: 11-06-2006, 11:09 AM
  3. Foobar?
    By greenman100 in forum PowerVoice
    Last Post: 12-19-2005, 08:41 PM
  4. Problem playing files
    By RuwKus130 in forum FrodoPlayer
    Last Post: 05-31-2004, 01:33 PM
  5. Replies: 3
    Last Post: 08-14-2003, 09:18 AM
