Results 1 to 10 of 13
Thread: read voltages from the M4 ATX?
    Mar 2011
    good evening, there is a way to read the voltage from the ignition +12 +12 in the software M4 ATX? or alternatively what exists?
    hoping for a Vs. response
    BR
    Carlo
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Ign voltage would be the same as the battery voltage, the m4 software should be reading the voltage coming into the power supply which would be battery voltage less drop. SNO
    Mar 2011
    Quote Originally Posted by SNOtwistR View Post
    For ignition I mean the "locked up." While the 12v is that coming from the battery. The software that provides min ibox is a tool that gives me these tensions. Is there a way to integrate them into lleggerle and RR?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Someone did it for CentraFuse, so it's definitely possible.
    http://www.centrafuse.com/apps/details/147
    if someone can get get hold of an SDK I can have a look at doing a plugin. (I do have an M4-ATX sitting around somewhere.)
    Mar 2011
    Quote Originally Posted by Enforcer View Post
    Thanks but Centrafuse has several things that I do not like. and it's not open source
    Sep 2012
    Germany - Munich
    Mar 2011
    Quote Originally Posted by harryberlin View Post
    Thank you but I do not know what to do with them.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Carlo201983 View Post
    I think that was aimed at me.
    Wow you are really on a missing the point roll.
    Mar 2011
    ah ok. then sorry
    Feb 2011
    it's offtopic but i'm checking the voltage directly before the pc turn-on, IMO is better an hardware check instead of a software one.. simply put a voltometer relay checker on ignition wire (the relay must have upper and lower voltage values so it will give/cut off power when needed)
  1. ATX Voltages
    By bgelb in forum Power Supplies
    Last Post: 08-09-2002, 09:32 AM
  2. Different voltages from LM2587-12
    By THEMP3KID in forum Power Supplies
    Last Post: 07-24-2002, 03:30 AM
  3. voltages
    By marsjell in forum Power Supplies
    Last Post: 06-03-2002, 12:04 PM
  4. Other Voltages from DC-DC PSU?
    By MrNiceguy in forum Power Supplies
    Last Post: 05-05-2001, 11:46 AM
  5. Strange PSU Voltages from DC-DC PSU
    By macphisto in forum General Hardware Discussion
    Last Post: 05-10-2000, 10:34 AM
