Results 1 to 10 of 12
Thread: remedia install problems
    Jun 2001
    netherlands
    Hi guys,
    can somebody make an step by step on how to install remediacar and which and what in what order to do
    i would really like to try this out but cant get it to work.
    any help is greatly appriciated.
    gerard
    time for the sig:
    '00 VW golf TDI upped to 130 HP - 18" RS 6 wheels - liliput 7" tft in indash housing - epia 10K - SB audigy - caliber 1 fahrad CAP - RF punch amp - hollywood 1.6K mono amp - boston acoustics pro - RF 10" DVD sub
    FLAC mauri's Avatar
    Jan 2004
    Read the readme.txt , configure whit Remedia.ini your adapt data.
    Mauri
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    Hello Gerard,
    I have just installed remediacar, and am impressed with the interface ! I just now need to get it to work. You need to make sure you have downloaded the mediacar app first. I installed this in the same directory as ReMediaCar. You also need to download at least one skin ! Then open the remedia.ini file and make sure that the directories point to the right places. When you get that sorted, the app visual app should work.
    That is were I am up to at the moment ! Good Luck.
    regards
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by kpjuk
    Hello Gerard,
    regards
    KPJUK
    You need to instal Winamp and Media Player Classic first, then unzip the Remedia files anywhere you want to run from. Edit the the Remedia.ini with your settings and that's it. There is a readme.txt with details of each setting, also on my links page (http://guino.home.insightbb.com/links.html) there's a link for the files you'll need to download, including two full skins (if you don't want to get them elsewhere). MediaCar has never been required to run my software, although, that does provide you a set of skins to play with -- the updated skins will provide you with a few extra options not included in MediaCar.
    Variable Bitrate Curly_cat's Avatar
    Jun 2004
    Ipswich, UK
    I keep getting an error messgae saying that I don't have a valid skin.
    I've tried pointing the remedia.ini at 3 different Media Car skin folders and I get the same result with all of them.
    Could someone lay it out in detail for me please.
    : Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
    : Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
    : BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Curly_cat
    You must point the skinpath to the location of a FULL valid skin (i.e. C:\program files\mediacar\skins\BrushMetal\ -- If you have the brushmetal skin in mediacar). You can download a full skin off my website (see the bottom of links page) or look around for some.
    This path is where all your image and menu files including mainly the "general.ini" and "menu.skin" files. If you get this error there's really only three possibilities: 1-the path is wrong, 2-the skin is incomplete or 3-the skin is invalid (invalid data) you should NOT enter the name of any file, just the path ending with \ )
    Let me know if you still can't get it... check readme.txt for details on other settings.
    Jun 2004
    Ipswich, UK
    Wink
    OK, fixed it. I was just being a bit ( or a lot ) thick.
    I hadn't put the "\" onto the end of the path to the skin and that's what was casuing it to not work. !!
    I'm happy now.
    Yeah, I know, little things please little minds.
    Nov 2004
    I have created an Install program for this. Just waiting on Guino to take a look at it, and let me know if he wants to use it or not.
    Should help fix alot of Install issues.
    2000 Yukon Denali
    Shuttle SN65G2
    Cel-D 2.4 GHZ 533mhz FSB
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    RF Mini Kb w/Trk Ball
    7" Lilliput Touch Screen Monitor
    USB 2.0 Hub
    Rikaline GPS-6010
    PN11 802.11b Wireless
    XP Pro
    750W Inverter
    Low Bitrate fishy's Avatar
    Oct 2004
    sydney
    hows it going?
    gday,
    love the work you guys do... how's the install program coming along?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by fishy
    gday,
    Ask bry21317 (above) if he can make an updated install -- I'd make it available on my site.. I have not worked on it personally because it takes way too long (relatively) to keep it up to date.. besides, RR doesnt really NEED to be installed, you can just unzip it somwhere, use the config tool to define your settings and you're done..
  1. problems with M10000 and WD 80GB HD
    By wyckyd in forum General Hardware Discussion
    Last Post: 08-05-2004, 02:33 PM
  2. Problems Rebuilding
    By Fender2Martin in forum General Hardware Discussion
    Last Post: 07-28-2004, 04:50 PM
  3. Carputer install
    By H3nrY in forum Newbie
    Last Post: 07-25-2004, 10:45 AM
  4. DLink DSB-R100 Install Problems
    By paiged in forum General Hardware Discussion
    Last Post: 07-20-2004, 06:56 PM
  5. Harddrive problems....bios?? or just OE
    By stinkynathan in forum General Hardware Discussion
    Last Post: 11-18-2002, 11:15 AM
