I tested all of them one by one, option by option. All you have to do is replace the code of a button (or create a button) using the examples in the Skin Commands.txt file (available now with road runner).Originally Posted by tolisn
A typical example would be to run an external command that does something (non-visual on the computer). I.e. renew ip address: "RUN:IPCONFIG /RENEW"
so the button code (complete) would be like:
B01,005,004,230,062,"RUN:IPCONFIG /RENEW",""
optionally you could specify the text to be spoken (when voice is on):
B01,005,004,230,062,"RUN:IPCONFIG /RENEW:Renewing IP address",""
Hope that helps,
Guino.
LinkBack URL
About LinkBacks
