Results 1 to 10 of 16
Thread: Serial port format ??
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    I am trying to build a shutdown controller board for my car PC and while at it I will include the temperature sensor circuit on the same board.
    What does the serial port expect to read from the temperature sensor board in order to display the correct information in Road Runner ?
    Great work Guino
    and Thanks
    FLAC mauri's Avatar
    Jan 2004
    Link http://quozl.us.netrek.org/ts/nk
    In this site you find the documentation, there and also the file source .asm.
    However it is not assembled with MPASM by Microchip, but with the old GPASM.
    If you succeed in creating the file. hex for the P12C509 make to know me that we develop or proper hardware.
    Mauri
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by tolisn
    Great work Guino
    and Thanks
    It's as simple as this:
    1: 72.6
    2: 34.6
    1: 72.8
    2: 34.4
    etc.
    it basically sends the data as the number of the sensor and temperature reading of sensor (cycling through all available sensors) -- The input scale can be F or C and can also be showed in F or C, all setup by INI file. The current board supports 4 Temp. sensors, but if you add more, I'll add support for more. Also, if you'd like to change the format for your board, I can add support for it as well.. this is all very simple stuff to do, so just let me know...
    Dec 2003
    Greece
    Ok thanks for the help. I will see what I can do.
    Dec 2003
    Greece
    Quote Originally Posted by mauri
    Mauri
    I cannot get the above link to work
    Victoria, TX
    http://quozl.us.netrek.org/ts/ works
    Dec 2003
    Greece
    Quote Originally Posted by Mr_Wizard
    Ok thanks
    Dec 2003
    Greece
    Guino.
    1. Their are no tempx setting in the RR.ini file. I tried useing the Configuration programm to set the communication port for the sensors but it does not write anything in the .ini file. The TEMPx setting is missing completely.
    2. With what baud rate do you communicate with the serial port.
    Victoria, TX
    Guino.
    Oops... my goof on that one. Sent fix to Guino.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Guino.
    I'll look at it since I'll have add a few more options anyway...
    ALSO: My bad on the temp data format.. it's just:
    "1 0045.67" instead of "1: 45.67" -- Although, my code can probably parse the two formats just as well.
    this is the setting I currently use for the Temperature sensor:
    baud=2400 parity=N data=8 stop=1
  1. serial port to game port adapter wiring
    By asif in forum General Hardware Discussion
    Last Post: 08-17-2006, 04:47 PM
  2. USB Serial Port Adapter Troubles
    By bLindmOnkey in forum General MP3Car Discussion
    Last Post: 10-13-2004, 11:29 PM
  3. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 08:48 PM
  4. how can I use my printer port as a serial port on win Xp
    By babas151 in forum General Hardware Discussion
    Last Post: 04-09-2002, 05:23 PM
  5. 1 serial port, 2 devices
    By Meatballman in forum General Hardware Discussion
    Last Post: 04-16-2000, 10:50 PM
