Page 10 of 12 FirstFirst 123456789101112 LastLast
Results 91 to 100 of 111
Thread: Road Runner -- New Version 2-2-2005 :)
  1. #91
    Feb 2004
    think i found a bug...when holding the scroll button for a loger time then releasing it, it doesen´t resume the song but jups to the next one instead, now, klicking on the rew button only makes it look like being pressed...then you have to klick again to make it jump back
  2. #92
    Nov 2004
    San Diego & Fort Hood, Texas
    OK, I dl'd it and extracted the files, now what? i can't seem to get it to work.
  3. #93
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Paradigm_Guy
    Well, basic installation is:
    -Download
    -Unzip
    -Run RRCongif.exe
    -Put in all your settings and preferences
    -Run RR.exe
    Now, PRIOR to doing the above, you must have a few things:
    -Full MediaCar/Road Runner skin
    -Media Player Classic
    -Winamp
    It is also assumed that you will select the appropriate paths for the above requirements in the config tool. If the above is too complicated, look on other threads for the InstallShield made by users.
  4. #94
    Nov 2004
    Ahh, this is the first CarPuter program I've installed. I guess I'd better look for the InstallShield file. I'm very computer literate, but these programs are completely foreign to me.
  5. #95
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Did you change something? I now can't send messages using findwindow(nil, 'RemediaCar').
  6. #96
    Victoria, TX
    Quote Originally Posted by 0l33l
    Try findwindow(nil,'RoadRunner')
  7. #97
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I couldn't just leave it as "RemediaCar" could I ? it's 'RoadRunner' now same functions should work... sorry for the inconvenience.
  8. #98
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by guino
    Ah! I'll hopefully do some coding tonight
  9. #99
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Small bug found.. When using a skin where the folder has a space in the name it will load up ok but not save that as the default or active skin to load whn the program starts again, you have to change it in the ini your self.
    Terran
    PS This is using the apperance function.
    Couple more bugs... the first one I think I can fix using the skin function. When going to MM the date ( which is on the right hand side of the screen ) over lays the X and return buttons. Using this same skin unchanged MC used to hide the date... What I probably will do it tell it to move or not be displayed on that skin.
    The second is that the play list plus button no longer just adds that directory music only so that you can select what tracks you want to play be folder only. Instead for some reason it does the same as the other next to it and adds to the whol play list which you cant clear. Again this may be a skin bug how ever works fine in the car, I have not changed it yet so I can work out functionality.
    Terran
  10. #100
    Jan 2003
    Quote Originally Posted by ccsnet
    The second is that the play list plus button no longer just adds that directory music only so that you can select what tracks you want to play be folder only. Instead for some reason it does the same as the other next to it and adds to the whol play list which you cant clear. Again this may be a skin bug how ever works fine in the car, I have not changed it yet so I can work out functionality.Terran
    Acutally - I found this does work, how ever after going in and out, selecting directories and making playlists, after a short while all you can do is add to the current list so this must be a bug.
    Another small note is that I have done a fresh install of winamp 5 lite and when your app starts WA comes to the forefront and can bee seen on the task and maximised bar rather than been hidden by the clock.... not major but for the sake of been tidy.
    Terran
    Last note on this. Closed the app on my desktop where I am testing and Winamp remained open
  1. Archive
    By liquid_smoke in forum PhoneControl
    Last Post: 07-23-2006, 04:01 AM
  2. SonyEricsson Phones
    By JanneZ in forum PhoneControl
    Last Post: 01-05-2006, 10:12 AM
  3. Controlling Road Runner with Sendmessage
    By Prem in forum Road Runner
    Last Post: 02-03-2005, 01:54 PM
  4. Nokia Phones
    By [iG] in forum PhoneControl
    Last Post: 01-19-2005, 01:59 AM
  5. Road Runner users...
    By ODYSSEY in forum Off Topic
    Last Post: 08-21-2001, 12:30 AM
