Page 11 of 12 FirstFirst ... 23456789101112 LastLast
Results 101 to 110 of 111
Thread: Road Runner -- New Version 2-2-2005 :)
  1. #101
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    -The "skin" function doesn't yet "remember" the last used skin -- no bug.
    -The date issue is a SKIN bug -- The ones I provide have no major bugs. I actually made the labels stay on top of buttons intentionally so one could potentially design a skin where the button labels are NOT part of the images.
    -The Playlist:
    "Play"/Center button adds folder and subfolders, and plays the selected song. (Erases previous playlist first)
    "+" adds the current FOLDER and subfolders into the playlist (doesn't clear playlist first)
    "+1" adds the currently selected ITEM into the playlist (Folder/Song) (doesn't clear playlist first)
    -Winamp: if you're using winamp only for Road Runner, make sure the "always on top" is not clicked and change the taskbar options to "System Tray Only". As long as those settings are used, winamp will come up but won't be "in front" of road runner". Mediacar's winamp actually has a INI setting for it to start minimized, the same can be done, but this is better for testing. PLUS I hated when MediaCar crashed and I had to kill winamp using task manager.
    Winamp will be closed when exiting Road Runner if:
    -You only have one copy of winamp open
    -You did not open winamp manually
  2. #102
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by guino
    -The Playlist:
    I agree but its seems to stop doing this after changing it a few times... I'll see if I can replicate the kep presses later on for you to follow.
    Terran
  3. #103
    Jan 2003
    Quote Originally Posted by ccsnet
    Terran
    As promised.....
    file list
    this dir only - my music folder
    file list
    this dir only
    file list
    all users folder - this dir only
    file list
    all to list
    file list
    all to list - at this point it added far more mp3s than I had selected - infact all the above DIRs and sub DIR's.
    At this point I tested add this dir only and it seemed to remove the list and start from scratch how ever it did not do this yesterday as I said.
    I'm wondering if its got some thing to do with the folder names having spaces / and been deeper down the file system than a root dir ?
    KEY:
    this dir only = '+'
    All to list = '+1'
    Terran
  4. #104
    guino's Avatar
    Nov 2004
    Toronto, Canada
    As promised.....
    file list
    file list
    this dir only
    file list
    file list
    all to list
    file list
    KEY:
    this dir only = '+'
    All to list = '+1'
    Terran
    Ok, + will do this:
    -when highlight is on a folder: go into the folder, add all of its files and subfolders, the exit browser.
    -When highlight is on a file: add all files of CURRENT folder and all subfolders of CURRENT folder, then exit browser.
    +1 will do this:
    -when highlight is on a folder: Add the highlighted folder's files to playlist (sub folders will depend on winamp) -- I meant this to add the folder without the sub dirs, if it isn't doing that (cause winamp might load everything) I can change/fix it.
    -when highlight is on a file: Add the single file to playlist
    File/Folder names should not matter at this point.
  5. #105
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    guino: test the sendmessages by sending a command multiple times. For isntance if I send GPS, and then close GPS, and then send GPS, Road Runner just disappears.
  6. #106
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by 0l33l
    Ummm... I'll double check on that... sorry...
  7. #107
    Jul 2004
    Berkeley, CA
    Ok... check all of them
    New version going to be today. No school tomorrow.
  8. #108
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I've added a bunch of prevention now against doing "stupid" stuff like call the GPS screen FROM the gps screen OR, Call the Audio Screen then Call the Browser and then again the Audio screen (instead of simply exiting). This should not give you more problems..
  9. #109
    Jul 2004
    Berkeley, CA
    Cool
  10. #110
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Cool
    Your "fix" is out now
  1. Archive
    By liquid_smoke in forum PhoneControl
    Last Post: 07-23-2006, 04:01 AM
  2. SonyEricsson Phones
    By JanneZ in forum PhoneControl
    Last Post: 01-05-2006, 10:12 AM
  3. Controlling Road Runner with Sendmessage
    By Prem in forum Road Runner
    Last Post: 02-03-2005, 01:54 PM
  4. Nokia Phones
    By [iG] in forum PhoneControl
    Last Post: 01-19-2005, 01:59 AM
  5. Road Runner users...
    By ODYSSEY in forum Off Topic
    Last Post: 08-21-2001, 12:30 AM
