Page 2 of 12 FirstFirst 1234567891011 ... LastLast
Results 11 to 20 of 111
Thread: Road Runner -- New Version 2-2-2005 :)
  1. #11
    Nov 2004
    Guino,
    I downloaded the Skins from your site, and your updates. Is this all I need? You told me something in PM the other day that it wasn't correct.
    Bryan
    2000 Yukon Denali
    Shuttle SN65G2
    Cel-D 2.4 GHZ 533mhz FSB
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    RF Mini Kb w/Trk Ball
    7" Lilliput Touch Screen Monitor
    USB 2.0 Hub
    Rikaline GPS-6010
    PN11 802.11b Wireless
    XP Pro
    750W Inverter
  2. #12
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by bry21317
    Guino,
    Bryan
    The full skins are already updated, the one "white" brushmetal in your first install had some bugs in it.. the full skins at my page are already updated.
    That is all you need, I am fixing a few bugs here right now so you might want to wait till tomorrow to work on this..
  3. #13
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    I'd remove that roadrunner icon from the config program.
  4. #14
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by 0l33l
    haha.. I actually DREW that (for the fun of it).. just need to find something better..
    I've just fixed up a few bugs and made it available again.. (1-31-05).. that is after I tried it in my car with a few different settings.. also had to add a path setting to Map Monkey in the config tool (it was sharing the external GPS setting -- not good)...
    Please let me know if you find/have problems with version 1-31-05...
  5. #15
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by guino
    yeah, just add gammacontrol=TITLE and when pressing gamma, the message will be sent to the window of that title.
    Gamma Control doesn't work Added gammacontrol=Form1 to mpc.ini and RR.ini in all the possible places. So then I have Form1 running and hit Day/Night and nothing happens
    This is in the 1/30 version... testing out 1/31 now.
    Code:
    unit Unit1;
    interface
    uses
      Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls, Forms,
      Dialogs, StdCtrls;
    const
      MY_MESSAGE = WM_USER + 442;
    type
      TForm1 = class(TForm)
        Button1: TButton;
        procedure Button1Click(Sender: TObject);
      private
        { Private declarations }
      public
        { Public declarations }
        procedure MessageReceiver(var msg: TMessage); message MY_MESSAGE;
      end;
    var
      Form1: TForm1;
    implementation
    {$R *.dfm}
    procedure TForm1.MessageReceiver(var msg: TMessage);
    var
      txt: PChar;
    begin
      txt := PChar(msg.lParam);
      msg.Result := 1;
      ShowMessage(txt);
    end;
    procedure TForm1.Button1Click(Sender: TObject);
    var
      txt: string;
    begin
      txt := 'Hello World';
      SendMessage(Form1.Handle, MY_MESSAGE, 0, DWORD(PChar(txt)));
    end;
    end.
  6. #16
    Jul 2004
    Berkeley, CA
    Ok... tested it on 1/31/05... same thing... nothing pops up
    [Edit]: this might be on my end. I made an app that should send the same message it doesn't respond
  7. #17
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Have you really used WM_USER + XXX values for custom functions before ? cause all the tests I did with VB returned me GARBAGE in wParam and lParam when using any WM_USER + XXX messages.. I could receive the message but only the WM message number would arrive correctly...
    The setting is supposed to be on RR.INI...
    Any chance you can your code on a DLL so I can simply use OLE/COM to use its functions ?
    I have just posted a "FIX/IMPROVEMENT" just for your gammacontrol, that is, I changed just the gamma function for you to try a different code, everything else is the same.
    EDIT: This is the new code:
    'Sends GAMMA Command to GAMMAControl
    Private Sub SendGAMMA()
    Dim t(6) As Byte
    'Build Command string (screw unicode conversions)
    t(0) = "G": t(1) = "G": t(2) = "A": t(3) = "M": t(4) = "M": t(5) = "A": t(6) = 0
    'Send Message
    SendMessage FindWindowByPartialTitle(GammaControl), WM_USER + 442, 0, VarPtr(t(0))
    End Sub
    FindWindowBy PartialTitle will match any window with Form1 in the title, even if part of a name, and it's not case sensitive.
  8. #18
    Jul 2004
    Berkeley, CA
    Ok... better idea! GammaControl is capable of receiveing command line parameters. So send "GammaControl.exe /switch". This will be much easier to implement, and its already done on my side
    For some reason the code that I posted only worked within the app itself
  9. #19
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Sounds great, just send me the darn thing and I'll add it.. OR you can just edit your skin code for that from "GAMMA" to "RUNQ;GammaControl.exe /switch" (or add full path if necessary) -- internally I'll probably make GAMMA be executed as the above..
  10. #20
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    Sorry - can't get Map Monkey to embed properly. Window Name is set as "Map Monkey", the path is set as the mapmonkey.exe path and the selection option is set as Map Monkey in the RR Config.exe file.
    Am I missing something? Thanks!
    EDIT
    Problem fixed - had the Map Monkey path in the wrong box - there were 2 boxes for GPS path in your config program. That's what happens when you rush through setup....
    -HD
  1. Archive
    By liquid_smoke in forum PhoneControl
    Last Post: 07-23-2006, 04:01 AM
  2. SonyEricsson Phones
    By JanneZ in forum PhoneControl
    Last Post: 01-05-2006, 10:12 AM
  3. Controlling Road Runner with Sendmessage
    By Prem in forum Road Runner
    Last Post: 02-03-2005, 01:54 PM
  4. Nokia Phones
    By [iG] in forum PhoneControl
    Last Post: 01-19-2005, 01:59 AM
  5. Road Runner users...
    By ODYSSEY in forum Off Topic
    Last Post: 08-21-2001, 12:30 AM
