Page 3 of 12 FirstFirst 123456789101112 LastLast
Results 21 to 30 of 111
Thread: Road Runner -- New Version 2-2-2005 :)
  1. #21
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by hd54321
    Sorry - can't get Map Monkey to embed properly. Window Name is set as "Map Monkey", the path is set as the mapmonkey.exe path and the selection option is set as Map Monkey in the RR Config.exe file.
    Am I missing something? Thanks!
    -HD
    Does it run, just not enbbeded, or doesn't run at all or runs and goes "behind" ? any more details ? I mean, I tested it both as External GPS and as Destinator Option... Also, did you get the 1-31-05 Version or the one I put out yesterday (few hours ago) ? I fixed a bunch of little things..
  2. #22
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by guino
    Sounds great, just send me the darn thing and I'll add it.. OR you can just edit your skin code for that from "GAMMA" to "RUNQ;GammaControl.exe /switch" (or add full path if necessary) -- internally I'll probably make GAMMA be executed as the above..
    Basically i'll just need command line parameters sent to gammacontrol and gammacontrol will handle the rest. Sorry for the whole sendmessages thing
  3. #23
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    Also, just found something - maybe i'm missing something again...
    When I choose long date in the config - it seems like it's too long for the title bar and gets overwritten by other text. Short date is okay.
    -HD
  4. #24
    guino's Avatar
    Nov 2004
    Toronto, Canada
    -HD
    Long Date is like: January 31st, 2005 ... your skin will have to allow plenty of space for you to use that.. but it is still an option...
  5. #25
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by 0l33l
    Had the code already in there for the SDK anyway.. didn't hurt to try...
  6. #26
    Jul 2004
    Berkeley, CA
    GammaControl v.7
    Use the NaviVoice config to configure the lat/lon for this.
    As promised, the command line switch is "/switch"
  7. #27
    guino's Avatar
    Nov 2004
    Toronto, Canada
    GammaControl v.7
    Cool, This works fairly well.. does the lat/long needs to be setup since we're simply using it manually controlled ?
    Also, what kind of licensing requirements does this have ?
    Thanks!
  8. #28
    Jul 2004
    Berkeley, CA
    Thanks!
    The lat/lon is for automatic gamma changes. So say you configure it correctly, the program will know the time that the sun sets and it will dim or brighten up the display accordingly
    Licence - well, its donationware (like NaviVoice) until someone wants to sell it.
    Glad it's working. If you have any suggestions then fire away (maybe changing the day with night when switching so that night mode would come before day, that sort of thing).
  9. #29
    Jul 2004
    Berkeley, CA
    Oh, also don't hardcode GammaControl.exe. This is because NaviVoice will have the same feature, and its dumb having NaviVoice and GammaControl fight over the gamma settings.
  10. #30
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Cool... right now, switch works... but the first time you run "/switch" it doesn't do anything, then the next run, it goes to "night", then on the following, goes back to "day", then the next it does nothing ... then the next goes night etc.. I mean: it is not completely alternating every time you run it... I think it might be switching between day/night and some auto/default setting in the middle.
    Regarding configuration, I could be nice to have it setup as long as whenever it loads up it sets up the screen to whatever it should be according to the lat/lon (On its start up I mean).
  1. Archive
    By liquid_smoke in forum PhoneControl
    Last Post: 07-23-2006, 05:01 AM
  2. SonyEricsson Phones
    By JanneZ in forum PhoneControl
    Last Post: 01-05-2006, 11:12 AM
  3. Controlling Road Runner with Sendmessage
    By Prem in forum Road Runner
    Last Post: 02-03-2005, 02:54 PM
  4. Nokia Phones
    By [iG] in forum PhoneControl
    Last Post: 01-19-2005, 02:59 AM
  5. Road Runner users...
    By ODYSSEY in forum Off Topic
    Last Post: 08-21-2001, 01:30 AM
