Page 5 of 12 FirstFirst 123456789101112 LastLast
Results 41 to 50 of 111
Thread: Road Runner -- New Version 2-2-2005 :)
  1. #41
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Not exactly....like say at 6pm it changes from day->night, but instead it dims a little at like 5 then maybe again at 5:30. So that as it gets dark it kinda follows the sun light instead of all at once. or like the dimmer nitelights they slowly get brighter as it gets darker but just oppisite...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #42
    Variable Bitrate ildena's Avatar
    Dec 2004
    Italy
    Quote Originally Posted by 0l33l
    What do you want??
    No, why would you want to have separate channels
    Because adjusting the channels in different ways you can leave a color as main fitting with the instruments panel lights...
    For example I have an MX5 with green instruments. Living the green channel up (as in mediacar) the monitor becomes black & green instead of black and white...
    Small things make difference!
    See my car and donate for spinning logos at www.ildena.it/carpc
  3. #43
    FLAC mauri's Avatar
    Jan 2004
    What do you want??
    What someone writes the string corrected by to use!
    Mine was a question!
    Mauri
  4. #44
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by mauri
    Mauri
    Just use "GAMMA" on the button code.. it is still not implemented in the current version..
  5. #45
    Nov 2004
    If you run the RRconfig.exe program and turn on Voice Enabled, then click Save. Click Yes to overwrite current .ini settings. Then open RR, you are not able to click on Any buttons, that worked prior to turning this setting on. If I click on the Music button, nothing happens, same thing with the GPS, which is supposed to open Map Monkey, also Exit doesn't do anything.
    Not sure if I am using the Voice Enabled correctly or not, but I turned it on, but don't yet have a Microphone to use. I do have all the SAPI software installed from your website links.
    As soon as I CTRL+ALT+DEL to close the program, which also still states iCar, then go back into the RRConfig program, turn off Voice Enabled, restart RR, everything works fine.
    Just figured I would through this out so that you are aware of it, if your not already.
    Also,
    I noticed that with the Alpine Skin, you can see the entire song name, artist all the items that are in the path. When I used the Brushed Metal version, from the guy doing the Ipod Wheel, I am getting just items such as track1.wma, track2.wma. Now occassionally I will get it to state the correct song names, when I click on the + to go into the folders, it will show them, but then goes back to not showing them. I do have all of the ID3 selections checked in the Config file. The only one that I don't have turned on is: Resume playing when start or unhibernate.
    Hope this helps.
    Thanks,
    Bryan
    2000 Yukon Denali
    Shuttle SN65G2
    Cel-D 2.4 GHZ 533mhz FSB
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    RF Mini Kb w/Trk Ball
    7" Lilliput Touch Screen Monitor
    USB 2.0 Hub
    Rikaline GPS-6010
    PN11 802.11b Wireless
    XP Pro
    750W Inverter
  6. #46
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by guino
    Ahhh,
    Mauri
  7. #47
    Constant Bitrate mpfjr's Avatar
    Jun 2004
    Corona, CA
    Dang I am lost. I decided to give RR a try today so I downloaded it from the website and extracted it to c:\RR
    Then I downloaded the updated alpine and brushed metal skins
    I created a skins directory in c:\RR\skins and dropped each extracted skin file into it. So I have c:\RR\skins\Apine & \skins\brushed etc..
    went into rr config and clicked the path box for skins and directed it to one of those skins. When I launch Road Runner I get an error that says the skin is not valid.
    What am I doing wrong?
  8. #48
    Constant Bitrate Partybuster's Avatar
    Amsterdam
    I guess you have to put the skins in the media car SKINS folder and use that path in RR. That's how I have it and it works OK.
  9. #49
    Jun 2004
    Corona, CA
    Quote Originally Posted by Partybuster
    voice=false
    musicpath=C:\Documents and Settings\MIKE\My Documents\My Music\
    videopath=C:\ftp\
    cddrive=d:
    dvdpath=Internal
    launchpath=c:\program files\mediacar\launch\
    winamppatch=C:\Program files\mediacar\ **changed as per post below
    skinpath=C:\Program Files\MediaCar\SKINS\AlpineUpdate\
    mpcpath=C:\Program Files\Media Player Classic\mplayerc.exe
    screentype=16:9
    videoautohide=true
    videohidetime=4
    hidemouse=false
    useid3=true
    showid3playlist=true
    showid3browse=true
    gpsmode=0
    mapmonkeypath=C:\destinatorApps\Map Monkey\MapMonkey.exe
    gpspath=C:\WINDOWS\notepad.exe
    gpsname=Map Monkey
    exitmode=0
    showicons=true
    showextensions=true
    titlesafter=-
    listfollowssong=true
    resumemusic=true
    audiorepeat=on
    audioshuffle=off
    dateformat=Short Date
    timeformat=Long Time
    Same result
    C:\Program Files\MediaCar\SKINS\AlpineUpdate\ does not contain a valid skin! Check your settings and try again.
    Why is it not valid when I took it from the website? I am missing something but what?
  10. #50
    FLAC mauri's Avatar
    Jan 2004
    Change
    winamppath=C:\Program Files\Winamp\
    to
    winamppatch=C:\Programfiles\mediacar\
    EDIT:if you have the mediacar in this directory.
    Mauri
  1. Archive
    By liquid_smoke in forum PhoneControl
    Last Post: 07-23-2006, 05:01 AM
  2. SonyEricsson Phones
    By JanneZ in forum PhoneControl
    Last Post: 01-05-2006, 11:12 AM
  3. Controlling Road Runner with Sendmessage
    By Prem in forum Road Runner
    Last Post: 02-03-2005, 02:54 PM
  4. Nokia Phones
    By [iG] in forum PhoneControl
    Last Post: 01-19-2005, 02:59 AM
  5. Road Runner users...
    By ODYSSEY in forum Off Topic
    Last Post: 08-21-2001, 01:30 AM
