Page 7 of 12 FirstFirst 123456789101112 LastLast
Results 61 to 70 of 111
Thread: Road Runner -- New Version 2-2-2005 :)
  1. #61
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by drait
    Not to thread jack, but this is related to the latest version of RR... when using the internal MapMonkey support (which I'm guessing used to be internal Destinator support) instead of External GPS, it still uses the External GPS skin definition instead of the destinator_gps.skin file. Is it supposed to work this way? Not that I'm complaining either way though, since I can just use the external_gps.skin file for my changes.
    Oops.. that was my bad.. never did realize there was a "DESTINATOR_GPS.SKIN" file.. I'm fixing it for today's release..
  2. #62
    FLAC mauri's Avatar
    Jan 2004
    Guino,
    i have download the new update, unzip this , and open the RR folder,Panda Antivirus displayed ( see the screenshot) type one viurs .....Panda crazy?
    Mauri
  3. #63
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by mauri
    Guino,
    Mauri
    I downloaded that directly from the author's page.. www.beyondlogic.org ... if there's a virus (which I seriously doubt) it's his fault..
    That file is NOT currently used by anything in RR so you can delete it if you want..
    Might still add one little change today..
  4. #64
    Maximum Bitrate carpcnoobie's Avatar
    Mar 2004
    I just downloaded the update you put up.
    Routis works great now in there. Launcher works great too! Still checking on the other stuff.
    This is like McDonald's, "I'm loving it!"
    Progress Meter:
    [|||||!||||'] 95% complete
    It's in... it's finally installed!!!! But never finished!
    "It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
  5. #65
    Variable Bitrate drait's Avatar
    Dec 2004
    NorCal
    Quote Originally Posted by guino
    Well, I suppose it should now be called mapmonkey_gps.skin
  6. #66
    Oct 2004
    Atlanta, GA
    Yummy Yummy Yummy ! This software is soooo great .. and gets better every few days !
    Lexus SC300:
    Shuttle SB65G2/P4 2.4GHz/512 Meg RAM/120G Drive/Dynamix 706 TS/M4-ATX PSU/Rikaline 6010 GPS/RR/iGuidance 4
    Corvette:
    VIA EPIA SP-13000/512Meg RAM/250G drive/M1-ATX PSU/Xenarc 7" TS/BU-353 GPS/RR/iGuidance 4
  7. #67
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'm keeping Destinator to maintain full compatibility with older Mediacar skins..
  8. #68
    FLAC mauri's Avatar
    Jan 2004
    One question about the Gamma Control.exe.
    I have setting correctly this, and adjust the gamma control setting to my use.
    But the function on gamma control of RR is not whit the same whit mediacar(push the adapt button and automatically launch the Day or Night gamma setting preview)?
    This function its manually every time that I have to have been changing for day to night?
    OK, has seen the automatic function in base to the time, however I thought as mediacar the thing it worked.
    Or mistake me?
    Thanks Guino for your patience with us
    Mauri
  9. #69
    FLAC mauri's Avatar
    Jan 2004
    Yes for security delete this file in the download (so much if nobody uses better it to eliminate)
    EDIT:new test. Yes , this one virus,Norton antivirus have delete in the same Panda antivirus,DELETE this file guys, is one hacking virus
    Mauri
  10. #70
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Mauri
    I have taken it out from the download files. but I am pretty sure that it has no viruses.. It does indeed mess with process/memory etc which could set a heuristic flag in "Panda" whatever... I decided not to use it since it might not work well in Win98 machines..
  1. Archive
    By liquid_smoke in forum PhoneControl
    Last Post: 07-23-2006, 04:01 AM
  2. SonyEricsson Phones
    By JanneZ in forum PhoneControl
    Last Post: 01-05-2006, 10:12 AM
  3. Controlling Road Runner with Sendmessage
    By Prem in forum Road Runner
    Last Post: 02-03-2005, 01:54 PM
  4. Nokia Phones
    By [iG] in forum PhoneControl
    Last Post: 01-19-2005, 01:59 AM
  5. Road Runner users...
    By ODYSSEY in forum Off Topic
    Last Post: 08-21-2001, 12:30 AM
